The only ones I have had covered were already turning loose from the headliner structure and the foam under the cloth was dead and crumbly. In that case you MUST remove the old dead foam. I have a friend who does auto upholstery and specializes in street rod interiors so I take his instructions, peel it off/remove the old foam and he covers it in original material. Usually $50 or less material and labor. That's why I've never done one myself.
Well then, You'll know where the JD dealer is, and I'm right behind there, just off of 401. Been here for a couple of years. I just put in a request to join your OBS group on FB. So you should be seeing that soon. You know we do a FTE Dinner once a month right? Usually it's not too much of a haul from this area.
I'll be moving to Fuquay-Varina in less than 3 weeks, I would be interested in participating in an FTE dinner. When will the next one be?
I found a place here (St. Pete, FL) that did a great job on my 2004 Buick LeSabre - It looks brand new. color was a perfect match, and the fit is essentially as good as factory.
He pulled everything, cleaned, re-glued, laid the fabric, and re-installed in about 2 hours. Cost $150. & that was for a full-size, 4 door passenger car. Not sure what the F150 would have been, but I'm sure it would have been less, and taken less time.
Check Google & Craigslist.
