1978 - 1996 Big Bronco
95 Bronco erratic voltage
Old Mar 6, 2015 | 10:02 PM
beatnbronco's Avatar
beatnbronco
My voltage gauge bounces rapidly between 14.6-15.1v. It does it at idle and acceleration, under load or without any load, from start to stop. I swapped alternators, disconnected my voltage module and disconnected everything from the battery(which is a brand new die hard) except the alternator and starter and it still does it. Does anyone have any suggestions? Thanks
Old Mar 7, 2015 | 02:41 PM
ZombieSlayer's Avatar
ZombieSlayer
More often than not fluctuating voltage is the result of a bad voltage regulator. You say you swapped alternators, did the new one come with a voltage regulator or did you use your old one?
Old Mar 7, 2015 | 11:51 PM
greystreak92's Avatar
greystreak92
That is a relatively small amount of fluctuation. You are talking about 0.5 volts. Automotive voltage regulators aren't that precise to begin with. Half a volt of fluctuation is not really cause for alarm. To be honest, that tiny amount could be a sticky gauge or even a loose negative to the gauge.
Old May 7, 2015 | 01:22 PM
beatnbronco
just to update, the problem is fixed and turned out to be a shorted diode on the rectifier.
Ford Breakdown
Aug 9, 2019 10:30 PM
jayro88
15
Oct 8, 2014 05:16 PM
98Stang
Oct 5, 2010 02:08 AM
Fords4all
1983 - 2012 Ranger & B-Series
Sep 9, 2003 11:19 PM
cozmo
Sep 27, 2002 10:52 AM
