smog equip removal
Old Mar 6, 2015 | 07:51 PM
shnazdabling's Avatar
shnazdabling
smog equip removal
Live in a state where emissions are no longer required as this awesome truck is over 20 years old.
I am desperately looking forward to removing all this archaic, underperforming, hp draining equipment now that it is legal to do so.
I have a 1991, F250, 5.0. Does anyone have any information on how to remove this emissions equipment? There's no way I'm the first person to do so. I suspect I could eventually figure it out on my own. But, I also suspect I would likely make several mistakes along the way unless someone is willing to provide some mentorship.
Anyone willing to help?
Old Mar 6, 2015 | 08:15 PM
Tedster9's Avatar
Tedster9
Are you sure it's legal? Anyway, the problem is by '91 the systems are so embedded I'd expect you have quite a task on your hand.
Old Mar 6, 2015 | 08:34 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
This is the thread I am following while doing it smog delete on my 88:
https://www.ford-trucks.com/forums/1...-302-5-0l.html
Trav
Old Mar 6, 2015 | 09:00 PM
Conanski's Avatar
Conanski
You can delete the whole smog(air injection) system without issue by simply following the lines back from the pump, this system makes up most of the mess under the hood of these trucks, just make sure the TAB and TAD solenoids near the coil remain electrically connected. The EGR is a very simple system in comparison just 1 tube from the passenger side exhaust manifold up to a valve that connects to the upper intake just behind the throttle body. This system can't be eliminated without setting codes and actually helps the engine get better fuel milage but do what you like. Removeing all this will definitely clean up the engine bay but it won't make any difference in power unless the air pump was partially seized.
Old Mar 6, 2015 | 09:13 PM
fordboy97's Avatar
fordboy97
Conanski I have deleted my egr and I have no CEL. I haven't checked for codes after the egr delete but I don't see how it would know. That is on my '90 though I believe on the newer trucks it is impossible to delete it without throwing codes.
Old Mar 6, 2015 | 09:14 PM
fordboy97's Avatar
fordboy97
Trav
Wow, that guy has a beautiful engine! Lol.
Old Mar 15, 2015 | 11:45 AM
shnazdabling
Thank you guys for all the info. Though there seems to be a few ways to go, this info is exactly what I needed. BTW, it is legal in North Carolina as the vehicle has aged beyond the emissions test requirements. It only requires a yearly safety inspection.
Really appreciate the excellent guidance. Thanjs everyone.
Old Mar 15, 2015 | 11:58 AM
Conanski's Avatar
Conanski
You will have a code for sure if you pull them but it may not set the check engine light, earlier trucks probably won't get a CEL from this while later trucks will because of changes in the way the computer is programmed. In all cases there is no way* to totally delete the EGR without setting a code.. even with the little plug that is supposed to fool the computer. The reason is the computer both commands the valve to move via vacuum from the EGR solenoid and watches for the resulting movement at the EGR position sensor, so even if you trick out the position sensor that won't stop the computer from sending commands to make the valve move and when the reading from the position sensor doesn't change it thinks there is a problem and sets a code.
* Well there is 1 way to prevent codes.. get a tuner and turn off all EGR functions in the computer.
Old Mar 15, 2015 | 12:38 PM
'89F2urd's Avatar
'89F2urd
you can leave the egr in tact, and plug the ends of the tube both on the lower intake and at the valve itself. this will give you the benefits of no egr and not keep the computer happy in the process.
Comanche1Star
Oct 27, 2024 12:41 AM
Joel Hamilton
Apr 28, 2019 09:06 PM
myoldf250
Jul 24, 2013 10:04 AM
square-body-lover
1978 - 1996 Big Bronco
May 22, 2011 04:27 PM
Stokes
Jan 7, 2003 03:02 PM
