cant add gas to filler tube
so the explorer will not allow the gas in................... I need to SLOWLY add fuel as the handle keeps tripping. it takes for ever....
I removed the filler tube from truck and blew air into it and could hear it in tank. I tried to blow thru the smaller tube (over flow maybe) and couldn't get air thru. i didn't try to remove lines from tank side yet. i used air from my lungs not a compressor too....
is replacing the lines the answer or am i missing something simple?
thanks.
thanks.
Sounds like you might have a vent solenoid issue that is not providing a vent to the tank when you're attempting to fill it up. You could also try removing your carbon canister and making sure it's not saturated. The carbon canister can saturate if someone overfilled the tank recently, such as trying to squeeze several more ounces in after the pump clicks off.
-Rod
-Rod
Sorry that might help
02 limited with v8 @ 113k miles.
Yes I triedto clean out the lines working from the top to the tank. I snaked the small line but it stopped right at the tank and wouldn't get thru. I stopped and put it all together because I didn't have the time to remove the tank and try- it also had a full tank so I thought to research awhile before I went farther......
john165
07-30-2014 04:01 PM
oldcoupe42
10-29-2003 03:36 PM
