I can't seem to figure out how to remove the neutral safety switch on my 99 expedition. I've removed the two bolts but it won't slide off. Is there a trick to this ?
Did you also remove the control lever (and it's nut) in the center? If so, it should now slide off. It could be stuck and in need of a little persuasion.
Got it figured out, it just slides off but it was real tight, thought I going to break it getting it off, but with a lot of prying it finally came off. Sorry if I wasn't specific enough alloro.
