OK my bad compression was 375 cylinder 1 and 380 cylinder 3. #3 was the one with the bad injector. Gonna order new ones from Ford Auto Nation. They gave me a great price last week $203 per injector. I'm surprised there isn't much to say about after market injectors. I would like to put bigger ones but afraid of reliability issues.
The thing that is good about OEM remanufactured injectors over the aftermarket is that Ford has access to all of the most up to date engineering data and are able to replace worn parts that the aftermarket doesn't have access to and from what I understand that all moving parts are replaced with new parts and come with a 2 year unlimited mileage warranty.
Local dealer sucks wont price match and wants $320 per injector. I hate the ford dealer here. Only time I used them is when the theft light was blinking and no one could work on it except Ford.
Wish you were a little closer to me. I'm happy with the service I get from my mechanic but when it came to a no start situation with the theft light blinking. No one would touch it around here only Ford. I'm in the Fingerlakes region in NY. Let me know when you open a shop around here!!
Are you sure that's after the core return? $320 - $100core = $220 which is about average for around here.
Yes I showed them the quote from autonation and they said they cannot meet or get close to that price. I don't know why I even bother asking anymore. Got all 8 injectors valve cover gaskets and fuel filters comming overnight they will be here tomorrow $203.50 per injector + $140 core charge.
Hey William, > > > > I worked a quote up for you for all 8 injectors to be replaced. If you're just staying on the topside of the motor it shouldn't be too bad. I will include a few gaskets and whatnot: > > > > 4C3Z*9E527*BRM 1628 + 1440 CORE INJECTORS > 3C3Z*6584*AA 24.17/EA VALVE COVER GASKETS > 3C3Z*9T514*AG 8.18 TURBO MOUNT KIT > > > > The turbo kit may not be necessary as some people can do this without removiing the turbo. > > > > It would cost around 16$ to ship via UPS ground. > > > > Hope this helps! > > > > Chris Yancey > > AutoNation Ford White Bear Lake >
this is the quote from autonation
$1628 for 8 injectors = 203.50 each
1140 core charge for 8 injectors = 142.50 each
</pre>
</pre>
Man,, hopefully your overnight fairs better than mine,, I had Chris overnight a body harness yesterday,,, It went on a plane to Louisville,, then got stuck there. Ground from mn is next day to me. Sux.
