ipr socket size
Old Mar 8, 2015 | 05:57 PM
tcjhkbjt's Avatar
tcjhkbjt
I have the sct 3015
Old Mar 8, 2015 | 05:59 PM
tcjhkbjt's Avatar
tcjhkbjt
So I guess either way I need to pull my oil cooler and look at the screen on the hpop? Does anyone have a good step by step video of how to do this?
Old Mar 8, 2015 | 09:37 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Well, your SCT 3015, also know as a SF3, has the capability of logging data and showing it back to you on the device's screen or you can download it to a computer and view it there. Here is a manual: http://www.sctflash.com/PDF/X3_SF3Manual.pdf
No way would I pull the top of the engine apart just to inspect the resivoir screen.
Many problems can cause a no-start. Here is a link to the no-start thread here in our Tech folder: https://www.ford-trucks.com/forums/8...condition.html
On your data, we will want to see ICP and IPR while the engine is cranking to know what's happening with the high pressure oil system, sync and FICM sync will tell if the injectors are firing, and FICM main power or FMP to asses the health of the fuel injection control module, and finally, cranking RPM.
It was mentioned earlier to pull the IPR, remove the screen, and flush out that end of it with some WD-40 or similar. Use a small screwdriver to push in the plunger a little bit while flushing. Because you found the previous screen broken, a small piece of trash in the plunger can hold it open and keep it from making enough pressure to start.
Once it's running and up to full operating temp we can evaluate if the oil cooler is bad by looking at coolant temp and comparing it to oil temp. That is unless you currently have oil in your coolant bottle.
Old Mar 8, 2015 | 10:17 PM
tcjhkbjt's Avatar
tcjhkbjt
Ok I'll look at those links. I did take out the ipr the other day and noticed the screen had a hole in it. I replaced the screen and I pushed in on the valve and sprayed some cleaner in it. How far towards the end should it spring back to. Anyone have a picture of a good ipr looking at it through the end? Maybe it is stuck open and I don't even know it.
Old Mar 8, 2015 | 10:36 PM
Rusty Axlerod
You can check the electrical side of the IPR on the bench with a multimeter. Reading across the pins you should get between 3 and 15ohms, most read around 6ohms. Of course open or full continuity is bad.
If you've already re-installed it, Pull out the middle PCM connector and ohm out pin #2 of the PCM connector by the driver side battery (yellow with red stripe coloured wire) to the positive terminal of the driver side battery at key-on/engine-off. (Yes, positive post with key on ).
Old Mar 8, 2015 | 10:43 PM
tcjhkbjt's Avatar
tcjhkbjt
Ok when I ohm that out I should be getting3-15ohms? If I do then my ipr is ok?
Old Mar 8, 2015 | 10:45 PM
Rusty Axlerod
The electrical side anyway, it could still be binding on the mechanical side.
Old Mar 8, 2015 | 10:47 PM
tcjhkbjt's Avatar
tcjhkbjt
Ok I'll try that tomorrow, should the plunger on the ipr come all the way to the end of the valve?
Old Mar 9, 2015 | 05:06 AM
Rusty Axlerod
I can't remember and don't have a good one here to look at.
Mustangking1
Dec 4, 2014 07:07 PM
Rickey Joe
Jun 21, 2014 07:06 PM
AllaboutMPG
Feb 14, 2012 06:52 PM
dagren99
Oct 25, 2011 06:00 PM
Fusion
Mar 16, 2003 01:01 AM
