1994 Ford E-350 - No start
The last time it ran was about a week ago, we've had a string of sub and below zero weather and I've already added a couple bottles of iso heat but still, to no avail. PLEASE HELP!
Read what you did, and checked for.
Your getting spark and signals at the injectors, That's a good sign.
My thought is your not getting Fuel. Yes, you checked the fuel pump and rail pressure, and that's good, BUT, our era of 5.8's the ECM controls the fuel pump.
First, check the Electric Fuel Pump Inertia Switch, located on the passenger side kick panel, make sure the red "plunger" is pushed down tight. If you take the panel off you can also check the incoming voltage with the key ON.
Next......Check or swap the fuel pump relay in the power control box, near/under the brake master cylinder. (should be the 2nd one from the front)
Next........pull the air box and air duct off to get to the throttle body, While cranking, spray some starting fluid into the TB and see if it want to catch, or at worst, see if you have back-fire from the intake. Prop the TB plate open with a stick or screwdriver, but don't let it fall out.
If it wants to catch (start) then you know you have a fuel delivery issue.
Pull the ECM out and open the case, see if any of the capacitors are leaking "green looking matter" If they are, the ECM will need to be replaced.
If the ECM checks out, and this is the one that killed me for a "no start".....Check/Replace the MAP (Manifold Pressure Sensor) located on the top of the A/C Evaporator Core. This can be "tested" and make sure the vacuum line is plugged in (on both ends)
If the MAP is not sending the correct signal to the ECM, the ECM will not sent voltage to the fuel pump relay, during the "run" cycle, no fuel, no start. The fuel pump will charge up the rail in the "on" cycle, but without the ECM reading the MAP (vacuum pressure) it will cut off the fuel pump circuit/relay.
Also, there's a LINK to the sensor testing
And read up on what the MAP is and does.
Good luck
Also, this is a box Van, does that change the location of the inertia switch, ECM, fuel pump relay or any other component you mentioned? I have located the MAP sensor.
Thanks for all your info!
Even the cut-aways, or "cube vans, box vans" which is what I've been working with for the past 13 years, first a '94 and now a '92, amazing how many parts are interchangeable over a couple of years
(Which is why I bought the '92)
The IAC would effect Idle, either with a high idle (which is also caused by a vacuum intake leak) or a start then stalling issue.
One you have the air ducts off the TB, and it's running, you'll see a little hole on the front right side of the TB, just cover that hole with your finger, if the engine stalls or drops RMP, then you have a bad IAC, and replacement is better than cleaning.
You can by-pass the IAC with opening the throttle plates with a small stick, that will let the "fresh air" into the intake.
Your describing a "No Start" issue, once you get it started, then you can see how the idle is, high or stalling (choking).
As I wrote, I think your going to find that this is a fuel delivery issue.
I was thinking about this today..........It might be possible that with the Extreme cold shot we had, that the MAP might have fowled out from the cold.
We figured that mine went when I had a major intake gasket leak, and it just kind of plugged it's self out??
If the check engine light does not come on you have no eec or power going too eec. Will crank and show a few other dash lights, but that us all.
You tried flood clear right? (flooring the gas, then trying to start it)
I would pull a few spark plugs to see if they are all wet
Do a code check just in case
The code test checks the processor and the noid lamp flashing while cranking is another indication that the processor is maybe okay
A good visual inspection of the capacitors in your processor is another test
