Alternator issues?
Old Apr 7, 2015 | 03:23 PM
Vwags's Avatar
Vwags
Sounds like you are making good progress but isn't 14.8v too high at the battery? I would never expect to see that much.
Old Apr 7, 2015 | 03:49 PM
pdqford's Avatar
pdqford
I found in the Ford Shop Manual that the alternator output should be between 13.0 and 15.0 volts at the alternator B+ terminal. (I can't access the B+ terminal while running as it is buried under the intake manifold so I read it at the battery + terminal.)
I'm hoping all is okay.
Old Apr 7, 2015 | 04:20 PM
Vwags's Avatar
Vwags
Well there you go. I haven't seen a charging spec that high. You are right it is up to 15v at 2000 rpm. Good on ya
1993 ford
Jun 16, 2017 04:40 PM
Deadsquiggles
1978 - 1996 Big Bronco
Jul 8, 2014 09:30 PM
Fluid Power
Jul 8, 2010 01:56 PM
r0n1n
Electrical Systems/Wiring
Jun 27, 2009 08:53 AM
southern//magic
Dec 23, 2007 08:20 AM
