Correct alternator voltage output?
Old Jun 15, 2017 | 09:39 PM
1993 ford's Avatar
1993 ford
Hi I have a 1993 Ford F-250 with a 7.3 non-turbo. Today I decided I would check the alternator voltage output to see what it was. So I got my load tester which also tells me the charging voltage and tried hooking up those big clamps on the little stud on the back of the alternator. After a big spark (don't think I hurt anything) I quickly decided to use my volt meter. My volt meter was reading 13.68 volts that seemed a little low to me. The truck had been running at highway speed for about an hour and it was pretty hot out (90 degrees with high humidity). The truck has always started good just decided to check the alternator for the heck of it. Is this a good charging output for my alternator?
Old Jun 15, 2017 | 09:53 PM
ctbiodzl's Avatar
ctbiodzl
Yes. Anywhere between 13.2 to 14V is normall. a fully charged battery should be
around 2.1V / cell or 12.6 volts at rest.
You can also watch the dash voltmeter immediately after the truck starts. The meter should climb quickly a couple needle widths, indicating a voltage increase due to charging.
Old Jun 16, 2017 | 08:29 AM
tjc transport's Avatar
tjc transport
i ain't rite
12.5 volts with engine off, and 13 to 14.5 volts with engine running, depending on battery charge condition.
13.68 volts at idle tells me your battery is fully charged and alternator is working fine.
never hook to alternator to test, hook the load tester or meter to battery.
the large lug on the alternator will always read the same voltage as the battery as long as the wire is good.
Old Jun 16, 2017 | 11:57 AM
whiteboyslo's Avatar
whiteboyslo
If that is with all loads off, it sounds a bit low. See what it is with lights, radio, and the fan on. It's not THAT low, but even on my original alternator, with no load I would see low 14s and only 13.8 with everything on.
Then again, so long as it's pushing out more voltage than the batteries see at rest (about 12.5), you're fine.
Mike
Old Jun 16, 2017 | 04:40 PM
1993 ford's Avatar
1993 ford
Ok good to know it's working right thanks for the help.
pdqford
Electrical Systems/Wiring
17
Apr 7, 2015 04:20 PM
8lug
Aug 24, 2012 05:50 AM
Fluid Power
Jul 8, 2010 01:56 PM
Polkster
18
Oct 14, 2009 03:43 AM
southern//magic
Dec 23, 2007 08:20 AM
