rear axle ratio
Old Jul 23, 2003 | 03:11 PM
jrsroadhauze's Avatar
jrsroadhauze
rear axle ratio
Hi, just purchased a 64 F100 SB and looking at the ID tag on the door a see a 12 for the axle ratio. Being a 73-79 guy that has a set of shop manuals for the vintage it tells me I have a 3:70 to 1 Would that be what your manuals indicate. The truck is a 292/3 spd. no overdrive. Also assuming that this is must likely a 28 spline 9" instead of a 31. This is an orginal truck, so I dont think anyone has made changes, but you never know!!And Ford used what ever they had toward the tale end of production.
Old Jul 23, 2003 | 06:04 PM
banjopicker66's Avatar
banjopicker66
rear axle ratio
For '63 to '65, Axle Code 12 indicates a 3300 lb Ford rear axle with 3.89 ratio.
Check the tag on the chunk to confirm.
Old Jul 23, 2003 | 10:26 PM
Rosati's Avatar
Rosati
rear axle ratio
The ratio should also be stamped on the pinion housing.
Old Jul 23, 2003 | 10:30 PM
airharley's Avatar
airharley
rear axle ratio
OK with that said what was the stock tire diameter? I was looking to do a gear swap for a set of 3.70's I was under the impression with as low of an RPM that I have at 60 that I have 2.90 or 3.00 in there. But when you factor in tire size that would slow it down too. Weighing my option since I need to buy new skins for my rims when they come in. Krosati what should I be looking for as far as teh stamp goes? I don't remember seeing one last summer when I scrubbed it down.
Old Jul 23, 2003 | 11:35 PM
Rosati's Avatar
Rosati
rear axle ratio
My mistake, My ratio is stamped on the flange but I don't think Ford did this from the factory. I think some body else did this at some point. I do still have the tag hanging as well.
The original tire size for 2WD F-100 were either of the following:
Optional 4000 lbs GVW - 6.70-15 2PR (front/rear)
RPM per mile (new tire) 772 at 36 PSI
Standard 5000 lbs GVw - 6.50-16 6PR (front/rear)
RPM per mile (new tire) 700 at 45 PSI
To get a target of 70 mph and rpms at 2500, you will need a ratio of 3.08 and tires diameter of approx. 28.97.
Check out this chart and use the bottom part of the chart to calculate. http://www.csgnetwork.com/multirpmtirecalc.html
Old Jul 24, 2003 | 07:21 AM
44dwarf's Avatar
44dwarf
rear axle ratio
I think I might have some 3.00's for a 9' rear that I'd trade for your 3.73 as I need gear cause i tow.
44Dwarf
Old Jul 25, 2003 | 10:52 AM
cobraguy's Avatar
cobraguy
rear axle ratio
44Dwarf I have a used 3.70 gear set I'm not using contact me at shelekelley(No Email Addresses In Posts!) if your interested. Put truck parts in the subject line.
Lee250
Jun 14, 2007 09:36 PM
BillWoeb
Oct 26, 2005 05:27 AM
64_f100_owner
Mar 3, 2004 08:40 AM
rowdy200
1997 - 2003 F150
Jun 18, 2003 09:55 PM
jonniekash
Jul 15, 2001 10:29 PM
