Does anyone know Sandblasting?
Old Mar 3, 2015 | 03:15 AM
Brad from Oz's Avatar
Brad from Oz
Originally Posted by Gary Lewis
I've started using the foam ear plugs, which work fairly well. But some sand seems to still get by them. Or, is it the sand draining out my head?
At least you only have sand, I've got rocks in my head !
The foam plugs are ok for low noise, but you have to insert them correctly. Decent ear muffs are the go, try the Bilsom black model with lead sheet insert in the cup if you can, they are the ducks guts. And keep your mouth shut, if you didn't know that trick .
Old Mar 3, 2015 | 07:10 AM
Gary Lewis's Avatar
Gary Lewis
Ok, I'll try the muffs I have for NASCAR next time I blast. Oh, and I'll keep my mouth shut about it. Mums the word.
Old Mar 3, 2015 | 07:36 AM
JordanL91's Avatar
JordanL91
I think (after looking into the overall pricing) That I may just use a small set up and wait for the compressor to catch up. Until Ive hit it big ill hold off on Brads Setup!!
Old Mar 3, 2015 | 07:37 AM
JordanL91's Avatar
JordanL91
I guess Sandblasting isn't for my ol' lady ... ummm I hope she doesn't snoop on my computer... lol
Old Mar 3, 2015 | 10:08 AM
bcamill's Avatar
bcamill
I sent the frame and body parts out due to the need for high air volume. In order to complete this task efficiently, you need at least a 60 gallon tank and a two phase pump. Now, it can be done with a 110 25 gallon 5hp oil free compressor, but you will need a lot of time to complete it. I have said compressor and own a sandblasting cabinet (the big one) from Harbor Freight. I only used medium aluminum oxide and all small parts and bolts came out great. The oxide does not damage threads and does not create a lot of heat if any. I spent four years working on my bullnose and plenty of time in junk yards getting some pieces. It may be worth sending the frame out as I assume you do not have a recovery system and you will expense a lot on sand or whatever you are using.
Old Mar 3, 2015 | 10:18 AM
Gary Lewis's Avatar
Gary Lewis
I agree with all of that but the bit about the two-stage/phase pump. When I bought my compressor I talked to a tech at Eagle Air. I'd settled on a two-stage pump and he quickly asked what I'd be doing with the air. When I explained that I would be abrasive-blasting, running air tools, etc he said that i should not go with a two-stage but a single-stage compressor.
He then explained that a single-stage compressor has two pistons of the same diameter pumping in parallel, meaning that both pistons are pumping directly into the tank. But a two-stage compressor has one piston the size of the two on the single-stage, and then one smaller piston. The larger piston pumps into the smaller cylinder, which then boosts the pressure and puts the air into the tank. So, a single-stage compressor is good for high volume with pressures up to about 100 psi, which is the max of most air tools, while a two-stage compressor provides less volume with pressures up to 175 psi.
Old Mar 3, 2015 | 04:06 PM
Diesel_Brad's Avatar
Diesel_Brad
Just a little FYI. Sandblasting creates Zero heat!!!! It is a MYTH that has been around for YEARS. Sandblasting sheet metal does NOT warp panels from HEAT. it warps them by shotpeening the surface for the metal. It stretches the surface.
in order to NOT warp the metal, you need to use LESS than 60psi and ooo sand(fine) or glass beads
Old Mar 4, 2015 | 03:27 AM
Ken Blythen's Avatar
Ken Blythen
Mums the word.
Well done on the spelling, Gary!
Old Mar 4, 2015 | 06:55 AM
Gary Lewis's Avatar
Gary Lewis
Ken - I never understood if that is a contraction of "mum is", and therefore should be "mum's", or not. Can you enlighten me?
Old Mar 5, 2015 | 04:13 AM
Ken Blythen
I think you are right with 'mum is', Gary (so, mum's)........no actual reference to mothers.
AFAIK, 'mum' is an old word for silent; so 'keeping mum' meant staying quiet.
From sandblasting to archaic English in one easy step
Old Mar 5, 2015 | 07:27 AM
Gary Lewis's Avatar
Gary Lewis
Thanks. And now, back to our regularly-scheduled programme.…
Old Mar 5, 2015 | 08:07 AM
JordanL91's Avatar
JordanL91
Only on FTE
Old Mar 5, 2015 | 08:32 AM
  #28
Gary Lewis's Avatar
Gary Lewis
Originally Posted by JordanL91
Only on FTE
Gotta love it. Not many places where you find such a wide diversity of people with a common love. Members from Australia/New Zealand to England/Italy/Germany, and Canada to Venezuela.
Old Mar 5, 2015 | 08:40 AM
  #29
ctubutis's Avatar
ctubutis
...and Podunk....
Old Mar 5, 2015 | 08:51 AM
  #30
Gary Lewis's Avatar
Gary Lewis
Originally Posted by ctubutis
...and Podunk....
How could I, especially I, forget Podunk? Actually, I didn't. It is implied as it is roughly 1/2 way 'tween all those places. But, it is kinda special so I'm glad you remembered and mentioned it.
Trojan8975
Aug 6, 2011 09:08 PM
82airborne82
Paint & Bodywork
Nov 9, 2010 07:15 PM
FordTrucksKickGM
Garage & Workshop
30
Nov 28, 2007 10:40 PM
MC1
Aftermarket Products
May 14, 2006 01:16 AM
mr4speedford
Garage & Workshop
Sep 27, 2003 09:54 AM
