Sponsored by: Auxito
4x4 issues
Old Feb 26, 2015 | 06:45 PM
Tiny2128's Avatar
Tiny2128
4x4 issues
Hi new here I have a 1997 f-150 4x4 5.4 liter single cab . Ok ever since I
Bought my truck a year ago the 4x4 light has been on . it still takes 4 hi and 4 lo
And pulls great but for some reason when you take it out of 4 wheel the light stays on I put new 4 wheel drive actuators on it and still the light is on also the plunger on the front is good to any suggestions would be greatly appreciated
Old Feb 26, 2015 | 08:44 PM
Bluegrass 7's Avatar
Bluegrass 7
You need to know how the dash light is lighted to trouble shoot the system.
First question is does the 4L come on for that switch position?
Does the 4L result in actual gear reduction?
These are important indicators of what the system is doing.
The dash lamp is actually lighted from a GEM module controlling separate leads to the dash lamps.
Going backwards, the firewall solenoid passes the light signal back through the transfer case motor circuit board, then back to the Module, for the light controls.
You can begin to see the importance of finding out what is or is not happening with the circuit and 4wd functions.
The front axle actuator does not control any functions other that lock together the left front axle assembly in response to vacuum being applied to it from the firewall solenoids.
Good luck.
wils3368
Aug 22, 2019 09:42 AM
sa_hobbit
1997 - 2003 F150
Feb 14, 2015 04:20 PM
soron3842
Mar 19, 2011 08:34 PM
f250inmn
2004 - 2008 F150
Feb 20, 2011 05:34 PM
Stay Marine
1997 - 2003 F150
Oct 11, 2006 07:17 PM
