New EX owner issues!!!!! HELP!
Old May 6, 2015 | 11:28 PM
ExPACamper's Avatar
ExPACamper
We put F350 springs on all four of my Ex. It was hitting and even wore out the bump stops with the old springs
I suggest you get help with this, though. It's a lot of lifting and coordinating lifts and such.
I would say I had lots of help, but it's more like I helped my buddies a bit LOL.
Front stabilizer (Bilstein) stopped the wobble that the "Worst state road in PA" put into her.
Hellwig rear anti-sway bar has helped quite a bit with body roll, but I think I'll adjust it up one more notch.
Something to keep in mind about your ride with worn out rear suspension- it may not pull evenly. There is axle slap, rotation, and other things that can make the ride rough and less than smooth (lots of folks here know much more than I do about suspension, so I'll let the detailed explanations to them )
Sounds like you're on the right track!
lonlyknight
Jul 1, 2013 10:48 PM
69oiler
May 29, 2012 06:12 PM
Chevy Convert
Jan 25, 2011 10:36 PM
helopilot
Mar 10, 2009 10:38 PM
sddesigns
Aug 19, 2008 06:37 PM
