So a couple weeks ago i locked on the hubs sit in my truck while going to work inside my truck i was hearing sound, while on the highway, coming from underneath the truck while driving over 50km every 10 seconde its feel like i hit a bump with the right tire ??? wonder if itsthe transfert case or maybe a bad locking hub any ideas??
You drove on dry pavement in 4 wheel drive?
If so you aren't suppose to drive on dry pavement in 4 wheel drive it is bad for it (not sure of everything that it ruins but I just know don't do it).
Trav
pull the large plug on the transfer case upper one and feel the chain slop-if it has a lot could very well be the transfer case-in that case do not use 4 wheel drive if it locks up from being wore out while your doing 40 or so you will not be happy trust me
you can also check the front axles by locking one in and rotating it listen and feel if it's binding-2 good places to start--keep us up to date on what you find
