1984 Ford transfer case problem
Old Mar 15, 2003 | 11:49 PM
mattandy30's Avatar
mattandy30
Question 1984 Ford transfer case problem
I have a 1984 Ford F-150 4x4 truck that the four wheel drive doesn't work on. I know it is not the hubs because i just repaced them and i know they lock in so I am thinking that it is something in the transfer case. Does anyone know what it might be I thought maybe it could be the chain but I am not sure.
Old Mar 16, 2003 | 08:20 AM
Boss_358's Avatar
Boss_358
First make sure that your T-case is working. Jack up the WHOLE truck and put in 4 wheel drive. Have someone look and see if the front driveshaft is spinning. If it is spinning and the front hubs are working correctly, then your problem is in your axle somewhere.
Old Mar 16, 2003 | 11:34 AM
steve83's Avatar
steve83
When you replaced the hub locks, did you pack them with grease?
Old Mar 16, 2003 | 04:47 PM
mattandy30's Avatar
mattandy30
No i did not pack the hubs with grease they said not too.
