Hatch Lift Struts/ Programmer
Old Mar 1, 2015 | 05:55 AM
PSUhoss's Avatar
PSUhoss
Originally Posted by WE3ZS
Darn, I was making plans to head to VA Beach to pick up those rims if you didn't make it through the hatch strut job, I mean they are already paid for and all..........
WE3ZS - that is great, good memory! I will leave them you in my Will for making me laugh out loud.
Old Mar 1, 2015 | 09:49 AM
sessland's Avatar
sessland
Originally Posted by PSUhoss
It is all good and went much better than expected. Took longer to find the right length prop than it did to do the swap.
With the longer travel, you can't replace them one at a time. They both have to come off before you can put one back on due to the length.
Best $35 I have spent on the rig so far. simple pleasures mean not bumping your head on the hatch.
That's where I can into trouble. I disconnected one side only for some extra safety factor, then I realized the error of my ways.
During the removal of the second lift support is when I dislodged what I was using to support the back hatch.
Old Mar 1, 2015 | 10:00 AM
ExPACamper's Avatar
ExPACamper
Me too
I need rear hatch struts, too.
Old Mar 1, 2015 | 10:58 AM
PSUhoss's Avatar
PSUhoss
Ouch! I bet that made quite a crash. Hopefully it didn't break the back glass. Around here that is a $400 mistake from a junkyard if you can find one.
I can recommend the longer ones from ebay that are provided by lift support depot. I am 6 foot and have plenty of room under the hatch.
Old Mar 3, 2015 | 10:00 AM
1Aauto's Avatar
1Aauto
Former Vendor
Hood and hatch struts have certain tensions that are set internally to provide the proper tension to lift the weight in the environment that they are made for.
If the tension is wrong on the strut, they won't hold the hatch or hood up properly. We carry hood and hatch struts on our website for your 2000 Ford Excursion.
Here's a link to them if you would like to see what we have to offer. 2000 Ford Excursion Rear Hatch & Hood Struts | 2000 Ford Excursion Rear Hatch & Hood Lift Supports | 2000 Ford Excursion Replacement Hatch & Hood Lift Support Struts At 1A Auto
Spaggs
Feb 26, 2010 04:48 AM
esco24
Nov 9, 2007 12:03 AM
carbine 1
Jun 14, 2004 08:58 PM
another_ford
1978 - 1996 Big Bronco
Nov 13, 2003 08:51 PM
