vac. pump question
Old Feb 23, 2015 | 12:29 PM
jvoss's Avatar
jvoss
vac. pump question
I have a 2006 6.0. I had the dead vac pump problem. Replaced it with new pump and everything worked fine for a month or so. Now the pump wont cycle at all. pulled pump and applied outside power source and it runs fine. Is there a specific relay/ fuse that controls power here? thanks
Old Feb 23, 2015 | 12:39 PM
mhoefer's Avatar
mhoefer
Check your manual for the fuse? The other thing to check is the prongs in the plug, are they all straight and making contact? One thing you can do is disconnect the pump line and see if disconnecting from the tank causes it to fire up? It only runs when it detects lack of vacuum. It's possible your system is just that good and No leaks. If will also engage when you put 4 wheel on or adjust the HVAC as vacuum is used for both.
Old Feb 23, 2015 | 12:50 PM
mhoefer's Avatar
mhoefer
My manual is for a 2005, its shows you should check fuse 31 and 33, but I couldn't find a reference to the vacuum pump specifically. This is the fuses under the steering wheel behind the panel.
Old Feb 23, 2015 | 01:01 PM
jvoss's Avatar
jvoss
I checked the prongs, hvac, 4wd not working. I will check fuses and let you know. Thanks for the info
Old Feb 23, 2015 | 01:15 PM
mhoefer's Avatar
mhoefer
I have had some strange times with my vacuum pump. See how you make out, but my old pump was coming apart and loosing its seal, it couldn't pump worth a darn. I juririgged it to work by zap strapping it back together so it could work well enough to have AC in the summer. They are plastic and the clips in the formed edges didn't hold well once deformed.
Old Feb 23, 2015 | 01:21 PM
jvoss's Avatar
jvoss
vac pump
Checked the fuses, found #23 climate controls as well. all good there. I will continue to work on it and let you know
Old Feb 23, 2015 | 01:22 PM
jvoss's Avatar
jvoss
Still not getting power to pump
Riverrat92
Oct 21, 2013 04:02 PM
Big Dirt
Oct 27, 2012 10:08 AM
rugermack
Jul 25, 2008 09:13 PM
resonance530
Jul 26, 2006 09:23 AM
enduringexplorer
Jul 12, 2005 10:55 AM
