Testing compression on a pulled engine
Old Feb 23, 2015 | 01:50 AM
johnwassink's Avatar
johnwassink
The engine turns over fine by hand I did put some oil down the glow plug holes initially just to give it some lube. But I'm not sure what the problem is but when I put power to the starter through a 850CCA battery, it doesn't turn over very well, it turns over slow and hesitates. I'm using jumper cables from starter to battery and a electrical wire from the starter hot to the solenoid...I complete the circuit at the battery w/ one of the jumper cable clamps.
I've tried another battery and both were fully charged but same result. Do I need two batteries at once to make it work?
Old Feb 23, 2015 | 06:02 AM
DieselDenny's Avatar
DieselDenny
2 questions:
1. Did you suck out the excess oil from the cylinders ?/Hydraulic lock possibly.
2. Did you reinstall the glow plugs on all cylinders before trying to crank it? If so and there is excess oil in the cylinders revisit question #1.
It doesn't take a lot of oil in the jug to increase the compression value to nearly impossible to roll it with the glow plugs installed.
Will it spin up freely without the plugs installed?
Denny
Old Feb 23, 2015 | 06:03 AM
Pikachu's Avatar
Pikachu
You need both batteries and an adequate wiring harness for both positive and ground. Jumper cables aren't going to carry enough current to do the job.
Old Feb 23, 2015 | 07:07 AM
johnwassink
Glow plugs are out and i can turn by hand.
That makes sense about the batteries and wiring harness, thanks!
Micka Wright Perry
Mar 19, 2016 03:46 AM
ou1dadgumit
15
Jul 2, 2014 08:18 AM
rougerocco
Jan 18, 2014 01:55 AM
89nolaf250
Feb 13, 2010 06:03 PM
justinthompson10
Jan 11, 2007 02:40 PM
