starting issue
Old Jan 16, 2014 | 11:36 AM
rougerocco's Avatar
rougerocco
starting issue
Question about my starter, Just did studs and head gasket job on my 04 Excursion, After found out the glow plug harness was bad, and replaced it. Now on a cold start, it won't crank. All the lights come on but won't crank until about 3-4 cycles of the glow plugs. Noticed today if i hold key in crank position, it will crank after glow plug light shuts off.(after 3-4 cycle).
Also new batteries and it starts fine when warm. Glow plugs tested OK. Don't know if I should be looking at the starter or glow plugs/ harness?
Just thinking might have wore out starter with all the extra cranking I put on it with bad harness and getting it fired up after stud job.
Kind of spent the max. on the stud job and don't have a lot of money to start shotgunning parts. Any help is appreciated!
Old Jan 16, 2014 | 02:44 PM
04badford's Avatar
04badford
Are all the grounds making good contact ? how does the Battery cables look? did work around the FICM make sure the connections are clipped in. Last resort pull the starter and have it tested, its been my Experience when the starter fails your done. Do you have any Gauges to read live data? I would look at FICM ( mp,lp,vp ) main power, logic power, vehicle power, and ALT for now.
Old Jan 16, 2014 | 05:14 PM
78fordman's Avatar
78fordman
I would check battery voltage when the glow plugs are on. Could possibly be the pullin voltage for the starter selonoid is higher than the battery voltage when the glowplugs are on. Check for 12 VDC while having someone hold it in the start position.
Old Jan 16, 2014 | 07:51 PM
ATV PRO #11's Avatar
ATV PRO #11
Would that indicate a bad starter if voltage was lower than 12?
Just with my plugs on I'm 11.2-11.6ish. Trickle charging overnight with those numbers.
Old Jan 16, 2014 | 08:02 PM
78fordman's Avatar
78fordman
Check for power at the starter while having someone hold the key to start. If it matches the battery voltage and is doing nothing I would take a close look at the starter. If it suddenly goes from 0 to battery voltage when starts to crank I would be checking the relay. 11.6 with the glow plugs on is what mine is at.
Sent from my leash using IB AutoGroup
Old Jan 17, 2014 | 02:22 PM
rougerocco's Avatar
rougerocco
**Up date**
Cold start today, after second cycle of glow plugs held key in crank position and as soon as the glow plug light went off it fired right up....thoughs?
Old Jan 17, 2014 | 04:10 PM
steelhead2's Avatar
steelhead2
Instead of holding the key in start, try moving it from on to start repeatedly and see if itll turn over after the first gp cycle. Sounds like your starter relay, or solenoid is giving you trouble.
Old Jan 17, 2014 | 07:41 PM
rougerocco's Avatar
rougerocco
That what I was thinking it might be....Will try in morning! Thanks!
Old Jan 17, 2014 | 10:55 PM
Yahiko's Avatar
Yahiko
Also it time to do a voltage drop test to make sure that
the positive and ground cables are good and not corroded
under the insulation.
Sean
Old Jan 17, 2014 | 11:45 PM
ATV PRO #11
Reps for that post Sean!!
Old Jan 18, 2014 | 01:55 AM
Yahiko's Avatar
Yahiko
I think that that Youtube video needs to be placed in the
Tech Folder. It's just way to handy.
Sean
Peter A.
30
Jan 30, 2017 09:20 AM
guthrie&co
Jan 13, 2014 09:41 PM
regidog
Apr 18, 2013 03:54 PM
lemonshindig
Feb 21, 2010 04:11 PM
Quick444
28
Dec 12, 2009 01:47 PM
