restoring a rollover
Old Mar 9, 2016 | 08:35 PM
Micka Wright Perry's Avatar
Micka Wright Perry
05 excursion 6.0 Heard I was suppose to removed glow plugs to purge possibly oil filled cylinders that was a job. Turned it over 2 twice with a 30 sec rest. Went to get new glow plugs, thought I'd turn it over again before install and nothing, might be the battery only had one hooked up. Could I have shorted something out just turning it over with glow plugs out? Also do you have to replace the plastic wire cover just above the glow plug cap/cork, they cracked just a small gap when taking them off.
Old Mar 9, 2016 | 08:40 PM
Twitchyleprechaun's Avatar
Twitchyleprechaun
Our trucks have 2 batteries for a reason, they need them both to start. I have never got mine to start on just one battery. Granted, I have only tried it 2 or 3 times, but it has not worked.
Old Mar 9, 2016 | 08:44 PM
Micka Wright Perry
Could be the battery but it would not even engage the starter where about 10 minutes before it was turning the motor. If there isn't enough voltage will it not even engage the starter?
Old Mar 9, 2016 | 08:51 PM
Twitchyleprechaun
Both batteries together will still send out 12volts, the issue is you don't have enough CCA.
Old Mar 9, 2016 | 09:06 PM
Micka Wright Perry
I hope that is the problem, I got worried I broke it trying to fix it. The one battery did crank the motor over about 10 sec then a rest and again about 10 sec but that could have been the end of it's juice in doing so, and there isn't much resistance with the glow plugs out, so the motor would turn easy if it would just engage. Just seemed weird that it was turning over just 10 min before.
Old Mar 9, 2016 | 09:11 PM
Twitchyleprechaun
I must have read through that part too quickly about it turning over before.
Old Mar 18, 2016 | 02:18 PM
Micka Wright Perry
definitely not a battery problem, guess I will start checking relays and fuses any hints?
Old Mar 18, 2016 | 02:21 PM
AZFX4's Avatar
AZFX4
Not sure on newer vehicles but older trucks had a switch that would engage if the vehicle was in a roll over (basically a check ball) if that was tripped you would have to go and reset it. Seems like that wouldnt be the case since you said it was cranking at one point.
Old Mar 19, 2016 | 03:46 AM
Apocalypse's Avatar
Apocalypse
All this does is shut off the fuel pump.
Micka Wright Perry
Mar 9, 2016 11:47 PM
bettyford93
Oct 31, 2014 11:45 AM
Opossum
Oct 17, 2012 12:18 PM
JTyler11688
Jun 24, 2009 09:27 PM
WesternAuto17
Sep 9, 2005 06:53 PM
