I recently purchased an 88 Ford F250 with the 7.5l. I was in the process of doing a tune up and came across this plug that is not plugged into anything. It is located on the left hand side just above the #1 Cylinder. Any thoughts on where it goes? I couldn't find anything.
I finally got around to taking a few more pics of the plug. It looks like the harness it belongs to runs down the passenger side of the block to the 02 sensor.
This one looks like the trailer wiring harness plug.
If this one belongs to the trailer harness where should it plug into? I am going to follow the wiring harness back this weekend.
Thanks,
If you have a trailer tow harness, there are actually two connectors like that. The harness plugs into those and runs down along the frame to the rear. I can get a pic for your this evening.
