Help with lost plug
Old Feb 21, 2015 | 02:35 AM
NJFord88's Avatar
NJFord88
Help with lost plug
Hey All,
I recently purchased an 88 Ford F250 with the 7.5l. I was in the process of doing a tune up and came across this plug that is not plugged into anything. It is located on the left hand side just above the #1 Cylinder. Any thoughts on where it goes? I couldn't find anything.
Old Feb 22, 2015 | 12:19 AM
TexasGuy001's Avatar
TexasGuy001
That looks like an EGR position sensor connector.
Old Feb 22, 2015 | 06:52 AM
EPNCSU2006's Avatar
EPNCSU2006
Not enough wires for EGR position. Canister purge valve maybe?
Old Feb 22, 2015 | 12:37 PM
stephandrusty's Avatar
stephandrusty
May be coolant water temp. sensor. Look around your top radiator hose.
Old Mar 8, 2015 | 09:23 AM
NJFord88's Avatar
NJFord88
Hey Guys,
I finally got around to taking a few more pics of the plug. It looks like the harness it belongs to runs down the passenger side of the block to the 02 sensor.
Old Mar 8, 2015 | 09:25 AM
NJFord88's Avatar
NJFord88
I also came acrossed another plug. This one looks to be part of the wiring harness associated with the SPOUT. Any thoughts?
Old Mar 8, 2015 | 10:06 AM
timbersteel's Avatar
timbersteel
That's the AC compressor plug.
Old Mar 8, 2015 | 10:40 AM
sgip2000's Avatar
sgip2000
Originally Posted by NJFord88
Hey Guys,
This one looks like the trailer wiring harness plug.
Old Mar 13, 2015 | 12:05 PM
NJFord88's Avatar
NJFord88
Could this be for something else other than the A/C compressor? The truck doesnt have A/C.
Thanks,
Old Mar 13, 2015 | 12:41 PM
sgip2000's Avatar
sgip2000
Thanks,
It looks like it had A/C at one time. It appears that the compressor was replaced with a "bypass pulley".
Old Mar 13, 2015 | 12:56 PM
NJFord88's Avatar
NJFord88
If this one belongs to the trailer harness where should it plug into? I am going to follow the wiring harness back this weekend.
Thanks,
Old Mar 13, 2015 | 02:16 PM
sgip2000's Avatar
sgip2000
Thanks,
If you have a trailer tow harness, there are actually two connectors like that. The harness plugs into those and runs down along the frame to the rear. I can get a pic for your this evening.
flare-f150
1997 - 2003 F150
Jul 20, 2015 06:42 PM
FordFan113
May 13, 2015 07:06 PM
KIDkiser
Jun 17, 2011 07:16 AM
jpcnorthwood
Feb 5, 2011 06:23 PM
dcrewchief
Sep 18, 2003 06:38 PM
