egr delete..............now????????????????
Old Jun 13, 2011 | 06:55 PM
KIDkiser's Avatar
KIDkiser
i just had the egr,and cooler deleted on my 06 f-250 today,now my temperarure gauge isnt working.the diagnostics on the dash says check coolant temp.the top hoses are hot,but the bottom is cool to the touch.any body know what gives?
<!-- / message -->
Old Jun 13, 2011 | 07:03 PM
2006powerstroke90's Avatar
2006powerstroke90
Stuck thermostate?
Old Jun 13, 2011 | 07:29 PM
npccpartsman's Avatar
npccpartsman
Sounds like they forgot to plug your temp sensor back in. It's on this picture just under the word "copper" at the very bottom in picture 2. 2005 Update Page 01 Running Updates
It's also #4 in this picture: http://dan.prxy.org/Truck/6L_bible_h.../Page_009.html
Old Jun 13, 2011 | 07:34 PM
steelhead2's Avatar
steelhead2
Cool bottom hose is normal,hot top hose is normal.the reason the bottoms cool is the t-stat holds the water in the rad,once the t-stat opens you get the cool water from the rad through the bottom hoseto the engine,t-stat closes,and the cycle starts all over again.check to make sure you plugged the sensor back in.its by the t-stat housing if I'm not mistaken
Old Jun 13, 2011 | 07:35 PM
BLADE35's Avatar
BLADE35
if the top hose on the radiator is hot then the thermiste opened
how long has it been since the work
I bet tim nailed it
Old Jun 13, 2011 | 07:39 PM
KIDkiser's Avatar
KIDkiser
just today,when it was first started the temp hand went all the way to the top,and then it just fell all the way to the bottom,and thats what it has been doing,also the truck doesnt seem as peppy.
Old Jun 13, 2011 | 07:41 PM
KIDkiser's Avatar
KIDkiser
the sensor is also plugged in
Old Jun 13, 2011 | 07:50 PM
BLADE35's Avatar
BLADE35
I know when my batterys been unhooked the first start the gauges will all go all the way up and then fall back down
also sounds like you have an exhaust leak to the turbo thats usualy the lack of power after this kinda work
start real fast and feel around ypipe and up pipes for exhaust leaks
Old Jun 13, 2011 | 07:53 PM
BLADE35's Avatar
BLADE35
check wire on temp sensor harness make shure it didnt get damage at the plug or the wire chaff
and welcome to fte
Old Jun 13, 2011 | 07:56 PM
npccpartsman
Interesting. Still sounds like wiring to me. Check your harness carefully for pinching/chaffing. Also, is your EGR valve plugged in? The truck not running as well is probably a defuel condition due to the check coolant light.
Old Jun 13, 2011 | 08:07 PM
KIDkiser's Avatar
KIDkiser
doesnt seem to be any leaks..the egr hole is blocked off with a plate,but then was laid on the intake and plugged back up.
Old Jun 13, 2011 | 08:09 PM
BLADE35's Avatar
BLADE35
at what coolant temp is that light supposed to kick on
I read in bismic spread sheet that the engine will defuel at 221f
I also see that a ect of 220f is commonly posted
Old Jun 13, 2011 | 09:11 PM
steelhead2's Avatar
steelhead2
Almost sounds like something shorted out the way the gauge hand swept.did you have the batts disconnected?. Like blades said mine to will do a full sweep after mine are disconnected.
Old Jun 13, 2011 | 09:20 PM
npccpartsman
Did you unplug it and check the terminals and plug? See if unplugging the sensor has any different affect on the gauge.
Also, while you're in that area, check the fan plug wires same area just above the fan on the shroud.
Old Jun 16, 2011 | 05:58 PM
KIDkiser's Avatar
KIDkiser
thanks everyone.turned out to be the ground wire behind the turbo.
