Well, it appears that my air leak is at the intake manifold. I got nothing on the boots or the intercooler. I just removed it because the donut o-ring was leaking coolant, not looking forward to trying it again.
That question is harder than it appears. After doing the intake I noticed that the hot side CAC boot from the turbo to the pipe was torn. It didn't feel alot different before than after because of that. I also didn't have the SCII before so I don't know normal yet. Working on it though.
I finally got a chance to check out the intake gasket and other possible issues. I found that I had an exhaust leak at the turbo inlet and at the EGR cooler. I also replaced the intake gaskets from Fel Pro to Motorcraft and followed the Ford torque sequence and spec. I now have power from 1/4 throttle to full throttle and she builds boost quick. Max boost I saw on the test drive was 18.5 PSI as opposed to 13 PSI if I was lucky. It also gets to the higher boost almost instantly vice only in 4th gear like before. I did the turbo relearn and got up to 21.5 PSI. She is way more fun to drive and I foresee a stupid speeding ticket in my future.
Thank You for all your assistance, it is much appreciated.
Reason: Post Turbo Relearn
Visually check the harness. Mine was obvious once I figured out while cranking had low rpm reported. The pigtail just as it goes into the sensor the wire was bare. Mine never threw a code or anything just occasionally wouldn't start. I was going crazy trying to figure it out!
You're getting up there but you're still missing out on about 6 fun points. (6 lbs of boost) properly sealed system can see 28 psi, and although the turbo can make alot more, the computer keeps it there. Keep chasing leaks. But atleast now it's driveable
I checked codes and I have a P132B. Looks like I do still have an air leak somewhere. I removed the EGR valve and cleaned it up, didn't have the gasket or o-rings to replace. That will be the next thing to try and seal.
