Identifying a CV Front End
Old Feb 19, 2015 | 05:17 PM
falcain's Avatar
falcain
Trailering
Could someone explain how to tell (without having the car as a reference) if a CV front end was removed from P71 Police Interceptor or standard car?
I have the opportunity to purchase the front end shown below for $200, but I'm not sure if it is from the correct year range and if it is compatible with my 64 F100.
Is this a good buy for $200?
Old Feb 19, 2015 | 05:50 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I found some info over on the crown vic forums and the post #3 seems to list some differences. If nobody here answers you might try a crown vic group.
what did I buy? - Ford Forums - Mustang Forum, Ford Trucks, Ford Focus and Ford Cars
See post #3 in the link. Might help. I'm guessing since it looks like it has a sway bar that your pic is of a P71.
Old Feb 20, 2015 | 07:08 AM
MCD46's Avatar
MCD46
Both p71 and standard front ends will work for the swap, as long as they are the aluminum, bolt in style (03+, i believe). I believe the difference is in springs and shocks.
What you have will work, and looks complete. You will need wheels with the correct offset also. For $200, that is a good deal.
Old Feb 20, 2015 | 10:54 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2003/2010 Grand Marquis & 2003/2011 Crown Vic's have rack & pinion steering, 1979/2002's do not.
Old Feb 22, 2015 | 07:35 PM
jlincks's Avatar
jlincks
this looks just like what i am having put in my truck. the only difference between the two is the shocks and springs. i got mine for $275 so under $200 is an awesome deal.
Old Feb 22, 2015 | 08:14 PM
falcain's Avatar
falcain
Trailering
I've noticed two different types of upper frame mounts. One looks to be aluminum and one style is steel.
Any idea why the two types? Does this have anything to do with the Police Interceptor vs the standard CV?
Old Feb 22, 2015 | 11:17 PM
jlincks's Avatar
jlincks
Well mine is a police interceptor front end and it appears mine is steel.
Old Feb 22, 2015 | 11:24 PM
jlincks's Avatar
jlincks
Was looking around at other çrown vic clips and ones that say they are police interceptors show aluminum top mounts. It may be that some years had them and others didn't.
Y2KW57
Dec 6, 2020 10:47 AM
52MercuryYellow
Dec 19, 2018 10:05 AM
Leebus
Aug 14, 2018 11:22 AM
Romak
15
Apr 24, 2010 01:06 PM
1975StroppeBaja
Jun 15, 2008 05:29 PM
