1966 - 1977 Early Broncos
302 Cold Starting Help
Old Feb 18, 2015 | 09:40 PM
dcombs's Avatar
dcombs
Hi Guys,
I recently bought a 72' Bronco with a 302. It has the factory motorcraft 2100 carb. I'm having some problem when starting it cold - It fires right up but idles a little rough (pretty normal as it warms up) but when I hit the gas - nothing happens. I keep letting it idle for like 5 minutes and the gas pedal will start to get a response.
This doesn't happen when it's warm outside. When it's warm - say 40ish degree and warmer it just goes fine. I thought it was the automatic choke - I adjusted it but still doing the same thing. I'm confused why I'm getting no response from hitting the gas (or if I open the engine and pull the throttle cable) when the engine is cold...
Thoughts?
Thanks,
Danny
Old Feb 19, 2015 | 06:13 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
You are on the right track. Make sure your "fast idle" is working. When engine is cold, pressing the accelerator once to the floor should close the choke and set the fast idle cam. A stepped cam on the side of carb. As it warms the choke opens and releases the throttle from the fast idle cam. Engine should start and run smooth when adjusted properly, though at higher rpm until warm. Normal for it to take a few minutes for idle to drop and respond properly. Just a characteristic of a carbed engine. You can Google search for the procedure on adjusting.
Old Feb 19, 2015 | 05:27 PM
f5fordgirl's Avatar
f5fordgirl
Remove the air cleaner, look down in the carb, then move the throttle, if you don't see any gas squirt out of the two nozzels, the excelerator pump isn't working.
TheCoach
Jun 17, 2014 11:18 AM
myfirstfordtruck
Apr 25, 2013 03:48 PM
bucks77ford
Sep 13, 2009 12:15 PM
clgreer
13
Dec 16, 2008 09:47 AM
fornarog
Feb 28, 2004 10:32 AM
