dumb question about block heater
Old Feb 17, 2015 | 12:50 PM
xaviar's Avatar
xaviar
Ok, is it possible to blow a fuze if the block heater is still plugged in when starting? Almost did this the other day and wondered if its possible to cause a short or something.
Thx
Old Feb 17, 2015 | 01:09 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Short answer - NO. But if there is anything ELSE wrong you can still blow a fuse. It won't be just because you have the block heater plugged it.
Old Feb 17, 2015 | 06:54 PM
Restlesswildman's Avatar
Restlesswildman
Blow a fuse on the truck? Not a chance!
Tripping a breaker in your house breaker box? Only if there is a serious issue with the block heater!
Old Feb 17, 2015 | 07:46 PM
WatsonR's Avatar
WatsonR
I start mine remotely and unplug just before I pull out.
Old Feb 17, 2015 | 08:21 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Thx
I'm assuming you mean house breaker/fuse. I would check you extention cord for cracks/fraying. When the engine is just starting, it could be twisting enough to short out the block heater hot to neutral or ground.
Old Feb 18, 2015 | 11:15 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Only takes a small amount of moisture to trip a GFCI
Josh
Old Feb 18, 2015 | 05:38 PM
mattdoc88's Avatar
mattdoc88
Some block heater manufacturers say to unplug before starting the engine. The flow of coolant can create small air bubbles near the heating element, shortening its life.
Flame Out
Feb 8, 2019 02:23 PM
dieselsmoker
6.4L Power Stroke Diesel
Dec 29, 2012 03:50 PM
FarmBoyFords
18
Jan 5, 2012 07:28 PM
canadajin
Modular V10 (6.8l)
Dec 14, 2009 05:19 PM
sommerfliesby
Jan 27, 2007 08:03 PM
