Hey everyone I have 2005 f250 Harley Davidson edition. I'm just wondering what else I should do. Right now I have arp head studs. Egr delete, 4in exhaust, blue spring mod, and sct tuner what else should I do? Any advice would be great
Oh yeah I had the stc fitting, stand pipes and dummy plugs put in when I got the head bolts put in. I'm just looking to make it more dependable at this point it is my only vehicle and it has a 100k on it
100k is just now starting to live
Other than normal maint you've done about everything you can for reliabilty except like stated a bigger alt, upgraded cables, and maybe a ficm from ed oohhhh and maybe a BPD water pump--that would be nice!!!
I would update the STC fitting, CCV reroute and add some Riffraff CAC boots. Maybe an alternator upgrade.
I normally don't buy things unless the are broke but the STC was important, my factory one had a little play in it when I replaced it.
I've been thinking about the ccv for quite some time--what are your thoughts? Sorry to op not meaning to high jack. I can start a new thread if need be
2006 F350 4X4
I'm not getting oil in my CAC tubes anymore and I like that. I just have mine routed down and under the truck. I think I'm going to add a filtered catch can. It hasn't dripped on the ground but I did notice a light film on my radius arm.
I gotcha. My Cac boots are bad oil soaked--which is why I'll be changing them.. Guess I should look at doing the reroute to keep all of my work clean.
Didn't see any mention of gauges. Assuming if you've got EGT and Fuel pressure at the least if you're running tunes. If not that would be my recommendation for next mods
