Hydra causing tranny problems?
Old Feb 16, 2015 | 11:29 AM
bleeds blue's Avatar
bleeds blue
So yesterday I pulled the hydra out and hooked it up to the computer to check for new codes. The only thing I added was the whisper mode. I put the chip back in and instantly had transmission problems. When I put it in gear the transmission does not immediately engage. Forward or reverse. When i push on the accelerator, it pauses and then slowly engages. There is also a noise coming from the tranny area that I can only describe as a hissing high pressure fluid sound?
Could the chip have anything to do with this or is it pure coincidence? I checked the fluid, its fine. I pulled the chip out and drove the truck, no change.
Is my tranny just finally giving up the ghost?
Old Feb 16, 2015 | 12:14 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
I'd call it coincidence.
I don't understand the "check for new codes" part of your post though.
Old Feb 16, 2015 | 12:17 PM
bleeds blue
I was hooking up to see what new codes were available, since I put it in a year ago. There were different ones, newer ones.
Old Feb 16, 2015 | 05:07 PM
Bonanza35's Avatar
Bonanza35
Pull it back out and see if it dose the same thing without it installed.
Old Feb 16, 2015 | 05:12 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
He already did.
Old Feb 16, 2015 | 05:46 PM
Bonanza35's Avatar
Bonanza35
Sounds like trans time then! I missed that somewhere I guess. Been there done that, Just all of a sudden trans messes up. Mine took 134K before I had to replace mine. Bother-in-law did three in first 100K, hit and miss.
Old Feb 17, 2015 | 02:54 AM
Stewart_H's Avatar
Stewart_H
Tunes. Custom tunes. I'm pretty sure that's what you mean since looking for new codes in the context you're using the term makes no sense.
Stewart
Old Feb 17, 2015 | 08:14 AM
bleeds blue
Stewart
Not custom tunes, didnt order any. Dont know how to explain it any further? I was just seeing if there were different tunes available from a year ago. There were. Lots of them. The only one I added though was the whisper mode.
Old Feb 17, 2015 | 08:15 AM
bleeds blue
Ok, yes, TUNES, not codes....... My bad.
Old Feb 17, 2015 | 01:09 PM
Stewart_H's Avatar
Stewart_H
LOL, doesn't it make you laugh when our brains glitch like that?
Stewart
lilman320
1983 - 2012 Ranger & B-Series
Aug 30, 2009 09:29 PM
fordpower88
Jul 7, 2009 09:35 AM
DRRXR
17
Mar 8, 2009 07:14 AM
Hotwheelbill
Dec 16, 2007 03:16 PM
pullinair
Jan 31, 2007 09:38 PM
