Sponsored by: Real Truck
Help 4X4
Old Feb 14, 2015 | 05:24 PM
DAVE LACLAIR's Avatar
DAVE LACLAIR
Help 4X4
Just purchased new auto hubs for my 2004 F250 , trying to install them they dont seemed to push all the way on so I can't get the retaining clip to go in the groove has anyone ever had that problem the hub I ordered
Dorman part#600-203
Old Feb 14, 2015 | 07:36 PM
senix's Avatar
senix
maybe this can help:
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
Old Feb 15, 2015 | 07:46 AM
hodge5's Avatar
hodge5
Can you give more detail? How far are they going in? Did you check for any obstructions (I'm sure you did, and that it would be obvious. Just have to ask). Did you try turning the dial or the axle shaft as you gently push it in? Are you sure that you received the correct hubs?
I replaced mine, and it only took a couple of minutes per side. If everything is right, they should go on quickly and easily.
Old Feb 15, 2015 | 08:25 AM
DAVE LACLAIR
Help
I did check for obstruction I ordered them from Dorman fits 99-2004 f250part # 600-203
drumdude
May 14, 2012 04:17 PM
sand_fiend
Sep 6, 2010 08:44 AM
alta825
Sep 20, 2007 07:10 AM
Racer1
Sep 15, 2003 06:55 AM
