4x4 front axle not working
Old May 14, 2012 | 12:25 PM
drumdude's Avatar
drumdude
I've got a 79 F150 4x4 with a dana 44 up front with lock-in hubs and a ford 9" in the rear. I was off roading the other day and it was working great. I put it in and out of 4x4 a couple times and it seemed totally fine. A few days later I locked my hubs but when I tried the 4x4, I heard loud snapping sounds from my front passenger hub. This happened a couple times as I tested it out and when it happened I would lose 4 wheel drive.
Is this a result of worn hubs that need to be rebuilt or replaced? My front drive shaft and axle look fine as far as i can tell. Also, is this safe to drive with the hubs unlocked and with the t-case in 2x4?
Thanks for any help you have!
Old May 14, 2012 | 12:27 PM
drumdude's Avatar
drumdude
**Also, I always have the hubs unlocked unless I am about to use four wheel drive**
Old May 14, 2012 | 02:42 PM
customrich&matt's Avatar
customrich&matt
hub
sounds like a bad hub
wont hurt to drive with
it locked out in 2wd
Old May 14, 2012 | 03:18 PM
crazy96863's Avatar
crazy96863
Your hubs don't actually hold the spindle on; they simply facilitate the mechanical connection between your axle shaft and the spindle assembly. Secondarily they also keep the weather out of your bearings.
As long as you don't hear any snapping or grinding or any sort of binding sensation, you should be fine.
Old May 14, 2012 | 03:28 PM
crazy96863's Avatar
crazy96863
Oh thought I would add... If your looking to fix this on the cheap, hit up a junkyard. You can use the OEM manual hubs from pretty much any bronco or f-150 all the way up to 96. The d44 ttb trucks have the 1/4 hubs where as the dents have the nearly full turn; this makes for a nice little upgrade for cheap.
When doing this you should take the hub along with all the internal components up to the spindle nuts; the solid axle hubs have different internal components than the ttbs and are not interchangeable.
You can probably do this for $10 - $15 a side or if you want shiny new drop $100 for a new set of warn or superwinch hubs; these might require a conversion kit that, if my memory serves me correctly, resembles the d44 ttb manual hub components with striking similarity.
Old May 14, 2012 | 04:17 PM
drumdude's Avatar
drumdude
Thanks guys, I will probably look for some hubs at a junk yard as soon as I get a chance.
....I guess I'll have to resist the mud for a little while though..
broncoking1994
1978 - 1996 Big Bronco
Jun 1, 2013 03:24 PM
'83f3fiddy
16
Jul 19, 2011 01:45 PM
FrontRangeF150
Apr 2, 2007 05:37 PM
ford_wheeler
Offroad & 4x4
Feb 6, 2005 11:27 PM
