Warn hubs - Help!
Old Sep 19, 2007 | 09:48 PM
alta825's Avatar
alta825
Warn hubs - Help!
I was getting a bit of a ratcheting type of sound from one of my Warn locking hubs so I took it apart and cleaned and lubed lightly. Now I can't get the sucker back on. well actually it is the c-clip on the axle end that i can't get on. the groove for the clip is 'inside' the hub assembley a few millimeters if you know what i'm talking about.
any tips to getting it back on? The hub slides all the way on, just can't get the smaller c-clip back on the shaft
Thanks for the help
Old Sep 20, 2007 | 12:27 AM
akmatt's Avatar
akmatt
i know your pain! what worked for me was to take a pry bar or screwdriver and pry on the back of the u-joint to push the stub shaft out far enough to get the snap ring back on shouldnt take alot.
hope this helps you, good luck
Old Sep 20, 2007 | 07:10 AM
alta825's Avatar
alta825
just the tip I was looking for
Thanks!
