Odd startup bogging.
Old Feb 14, 2015 | 04:23 PM
wils3825's Avatar
wils3825
Hey guys,
I've already scoured the internet a bit, and discovered that as usual, it is not nearly as helpful as you guys are.
'95 F250 Powerstroke.
On firing, it will lug down for a moment, then return to a normal idle. I hear an odd "Wsssshhhhh" sound that I assume is from the exhaust system while it bogs. I wondered if my EBPV could be sticking/damaged. I also sorta wondered if it could just be turbo related (Eg- the bearing/shaft the wheels ride on being worn) Any other thoughts?
Old Feb 14, 2015 | 07:50 PM
wils3825's Avatar
wils3825
second, and totally unrelated question- How much can I overfill my ZF-5 by before I should be concerned about blowing a seal, such as on the shift tower, etc?
Any guesses?
Old Feb 14, 2015 | 08:02 PM
oldbird1965's Avatar
oldbird1965
Sounds like your EBPV is sticking, unplug it, its not needed.
If you pull the intake off the turbo, pull back and forth and side ways to see if there is any play in the shaft. If its pretty tight, your OK.
Old Feb 14, 2015 | 08:07 PM
wils3825's Avatar
wils3825
Perfect. I'll check the play in the shaft tomorrow. Thank you for the help!
Old Feb 15, 2015 | 01:09 AM
stainlessstroker95's Avatar
stainlessstroker95
You can put 5 quarts in your trans and it should be just fine. That should help with gear rollover.
Old Feb 15, 2015 | 07:16 PM
wils3825's Avatar
wils3825
Thanks, Stainless. I'm hoping it gets rid of rollover, and the grinding I have in 2nd gear when I let the clutch out....
Old Feb 15, 2015 | 07:18 PM
Talyn's Avatar
Talyn
the EBPV is the woosh.
most of us here overfil our ZF5's by 1 to 2 qt's
I'd look to remove that EBPV eventually.
They are a ticking time bomb.
just my .02
I went though 4 gallons of oil getting home that day and a blown turbo.
Old Feb 15, 2015 | 08:16 PM
finitetime's Avatar
finitetime
great thread I've had some of the same problems when starting out. Now I know how to fix it.
Anything you can add to a zf5 to help it out.
Old Feb 15, 2015 | 09:19 PM
wils3825's Avatar
wils3825
I'm thinking a full delete is in order this summer. I found a couple of videos on youtube showing the leaks that they can cause, you aren't kidding about them being a time bomb
Thanks for the input, guys.
I added a quart through the shift tower, we'll see if it helps out.
Old Feb 16, 2015 | 08:37 AM
Hussler's Avatar
Hussler
On start up the EBPV cycles (closes then opens). It's suppose to do that as the PCM is checking for back pressure to see it that function is working properly. If the PCM see no extra back pressure then it disables the function for the driving cycle. If the EOT is high enough, > 135 F on my truck then PCM doesn't do the cycle check and the function is disabled for the driving cycle.
Old Feb 16, 2015 | 11:44 AM
cowmilker08's Avatar
cowmilker08
It sounds like the EBPV is functioning as it should.
leviticus
Apr 22, 2009 12:48 AM
joe blow
Mar 19, 2009 07:38 AM
indebt
Mar 18, 2007 06:29 PM
herrfixit
May 10, 2006 08:04 PM
kalsc
Jul 1, 2005 02:09 PM
