I've already scoured the internet a bit, and discovered that as usual, it is not nearly as helpful as you guys are.
'95 F250 Powerstroke.
On firing, it will lug down for a moment, then return to a normal idle. I hear an odd "Wsssshhhhh" sound that I assume is from the exhaust system while it bogs. I wondered if my EBPV could be sticking/damaged. I also sorta wondered if it could just be turbo related (Eg- the bearing/shaft the wheels ride on being worn) Any other thoughts?
second, and totally unrelated question- How much can I overfill my ZF-5 by before I should be concerned about blowing a seal, such as on the shift tower, etc?
Any guesses?
I'm thinking a full delete is in order this summer. I found a couple of videos on youtube showing the leaks that they can cause, you aren't kidding about them being a time bomb
Thanks for the input, guys.
I added a quart through the shift tower, we'll see if it helps out.
On start up the EBPV cycles (closes then opens). It's suppose to do that as the PCM is checking for back pressure to see it that function is working properly. If the PCM see no extra back pressure then it disables the function for the driving cycle. If the EOT is high enough, > 135 F on my truck then PCM doesn't do the cycle check and the function is disabled for the driving cycle.
