6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Radiator
Old Feb 13, 2015 | 10:09 AM
Softballdad's Avatar
Softballdad
Radiator
On Monday with 108k on my truck I had the leaking radiator, pulley, and tensioner replaced under warranty. The only cost I had was the upper/lower radiator hoses and belt. They tested the t-stats and said they were fine, so no need to worry about them. Are the t-stats a concern? I don't recall reading there being a problem with them, and wonder if I should have pressed more to have them changed. I'm not getting high temps and the oil and coolant temps are pretty close to each other so maybe there's no concern.
Old Feb 14, 2015 | 11:10 AM
fatboytx's Avatar
fatboytx
You can find youtube videos of bad 6.4L thermostats. I guess they hyperextend and get stuck. I've got a new set to throw in next time I flush the cooling system.
Excursioner69
Oct 27, 2017 02:52 PM
coolfeet
May 10, 2017 07:39 PM
SmackDaddy
Apr 4, 2017 11:00 AM
akblackfoot
Apr 3, 2017 03:49 PM
jnorris323
Aug 18, 2012 04:16 PM
