2002 Excursion Radiator Durability
Old Oct 12, 2017 | 09:58 PM
Excursioner69's Avatar
Excursioner69
My 2002 Ex has a plastic radiator resevoir and i am curious about the overall durability of these radiators. I use my Ex as an overland camping rig almost exclusively, so being miles off grid with a weak radiator or components is a concern. My buddy just had his toyota radiator blow apart on him way off grid and he has a similar plastic resevoir like me. Just wondering what y'all think.
Old Oct 13, 2017 | 08:35 AM
Oldguyfl's Avatar
Oldguyfl
A new radiator and coolant tank is cheap enough, just replace it and have piece of mind if you need that. Then you can do all the hoses, water pump, thermostat and flush at the same time.
Once you get that done, chances are then something else will let you down
You might be worried about nothing, but then don't know how your X has been maintained in the past. Radiators don't appear on here to be big failure items.
What about everything else that could POSSIBLY go wrong, you will drive yourself nuts.
Old Oct 13, 2017 | 11:20 AM
pirate4x4_camo's Avatar
pirate4x4_camo
Don't forget the fan clutch, belt tensioner and belt. Anyone of those failing is just as crippling as a faulty radiator.
Old Oct 13, 2017 | 02:34 PM
jspence105's Avatar
jspence105
My radiator blew out before the overflow. That was more than 3 years ago and I still have that overflow. Trying to guess what will fail will drive you nuts and cost a lot of cash.
Old Oct 15, 2017 | 12:04 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
My plastic-tank radiator failed on me while pulling a buddie's 5th wheel. The tank on top (right at the hose) cracked just under the hose connection. I couldn't see it, so I couldn't figure out where all the coolant was coming from for a while. I initially thought the clamp wasn't tight enough. Fan was slinging coolant all over the place. Really made a mess. That was at about 240k miles. I replaced with all aluminum option. Have had no problems since. Just turned 300k.
Old Oct 15, 2017 | 11:45 PM
Excursioner69
Thanks NicMike. That is what I was hoping to hear, general experience with durability and estimated life expectancy. I am at 152k currently so I think I will simply monitor the plastic overflow for cracks before each trip I go off grid.
Old Oct 16, 2017 | 12:28 PM
hasteranger's Avatar
hasteranger
I've got 190k on my stocker and it's still working but I do have a coolant leak at the front of the motor I'm trying to locate and it never occurred to me that it could be the radiator. One more thing to look into. I know in the off road community the plastic end tanks often separate from the aluminum where they are crimped because of the flex from severe use.
Old Oct 16, 2017 | 05:03 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by hasteranger
I've got 190k on my stocker and it's still working but I do have a coolant link at the front of the motor I'm trying to locate and it never occurred to me that it could be the radiator. One more thing to look into. I know in the off road community the plastic end tanks often separate from the aluminum where they are crimped because of the flex from severe use.
We've had 3 1st gen Explorers, an Exped and an Excur with the plastic tank crimped seal radiators. One Explorer went 218k with no problems, but blew a freeze plug at 20 years and died. The other 2 Explorers at around 25 years had around 110k on them - one had a leak near the input hose (hottest water) and the other had a tank split. The 2003 Exped has 170k and the 2002 Excur 120k with no issues.
The aluminum core has tabs that are bent over holding a seal against the plastic tanks. I suspect with age/heat (20+ years / 200k+) the tabs weaken and the plastic can split. I figure when I get 20 years or 200k on the Exped or Excur I'll get new radiators.
Old Oct 16, 2017 | 06:20 PM
jspence105's Avatar
jspence105
Mine blew out in the same spot. Towing on the interstate in 95F. I had about 190k on it when it went.
Old Oct 16, 2017 | 07:36 PM
msuser92's Avatar
msuser92
Mike, how did you pull that 5th wheel with your Excursion? Something like this?
https://www.youtube.com/watch?v=XixtZqpILm4
Old Oct 16, 2017 | 08:21 PM
andym's Avatar
andym
I'm going to guess that's a link to a TowBuddy or equivalent. You have to put a space in between the URL and any smileys of the parser will think the smiley is part of the URL (as is did there).
Old Oct 16, 2017 | 08:33 PM
msuser92's Avatar
msuser92
I think I fixed it. At least it worked after I edited it. And no it's not a TowBuddy.
Old Oct 17, 2017 | 12:17 AM
Stewart_H's Avatar
Stewart_H
I think I fixed it.
Nope, you still have the smiley with the url address.
Here ya go:
I haven't seen that vid (or of the same thing but with the VW bug) in a long time! Reps!
Stewart
Old Oct 17, 2017 | 06:42 AM
jcthorne's Avatar
jcthorne
The problem with the radiator plastic inlet is replacing the OEM clamps with screw drive clamps that un-evenly load the plastic neck. Stick with the spring lock clamps on the plastic radiator necks.
Old Oct 17, 2017 | 09:50 AM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I refer to any large travel trailer as a 5th wheel out of habit. My bad. It was a bumper pull.
In regards to the video, I love the idea. The problem isn't that they aren't made any more, it is that the tow vehicle in the video isn't made like that anymore.
Jcthorne, you are likely very correct in your observation. My X came with worm drive clamps on it when I bought it, and the neck broke right under the worm drive clamp. I now have t-bolt clamps on my all-aluminum replacement, so I don't have to deal with that anymore.
