Getting ready to do maint.. need input
Old Feb 13, 2015 | 11:51 AM
SaintITC's Avatar
SaintITC
If everything is coming out, a complete cleaning of the valley, and resealing the intake manifolds (or maybe an upgrade?). I like paint, white paint. Yeah it's a little messy, this was from last summer. But it's not for looks, it's to aid in any future leak finding..
Old Feb 13, 2015 | 02:13 PM
AllaboutMPG's Avatar
AllaboutMPG
Originally Posted by F250_
If you're doing the injectors, would now be the time to do the cups as well? You're already deep in there, and to have to do the cups later would be a complete "dig in" all over again.
I thought about it Pete but compression test is good and Blackstone showed zero coolant and zero fuel in the oil. With all the cup trouble others have had I decided to leave them alone. I may regret it later, we'll see.
Old Feb 13, 2015 | 02:15 PM
AllaboutMPG
What did you clean the valley with to get paint to adhere, how's it holding up? I like the idea just not sure I'll have the time.
Old Feb 13, 2015 | 02:20 PM
AllaboutMPG
When I made the list I forgot about the box of fluids sitting in the garage for about 2 months now. I will also be doing:
power steering flush (after I change the high pressure line now)
front, rear diffs swapping over to full synthetic
trans case fluid (NOT Mercon V)
complete tranny flush
Old Feb 13, 2015 | 02:24 PM
SaintITC's Avatar
SaintITC
When I started I didn't realize just how big the drain hole at the back of the block was, so a lot of crud went down that path (had a long time EBPV solenoid leak). Anyway, I used a long screwdriver and scraper to break up the thick stuff and vacuum it out. I would start in the back by the drain so you can prevent crud from falling thru. Then it was mostly soaking it with acetone, which broke down the oils, more scraping, wiping, vacuuming. Eventually I went to simple green and water, scrubbing and letting that drain through the hole into a catch pan. Then it was a paint thinner wash & dry & repeat, using a halogen shop light to dry it. Then plain old Rustoleum oil based protective enamel with a cheap brush. Two coats and I used the halogen light to "cure" it overnight. This photo was taken today, after wiping it down from the HPOP & turbo removal. My turbo was leaking oil, so it was a mess again, but wiped up well.
Old Feb 15, 2015 | 06:58 AM
AllaboutMPG
Originally Posted by F350-6
Depending on how old the line is, you might consider changing the high pressure line from the power steering pump. That seems to be the one thing everyone overlooks until it blows.
I believe Clay sells the seals you need for the fuel lines if you're ordering the other stuff from him.
Chris,
Is this the line in question.
Old Feb 15, 2015 | 06:01 PM
mueckster's Avatar
mueckster
Originally Posted by AllaboutMPG
Chris,
It is the one with the swivel connection on the side of the p/s pump. It is the swivel joint that usually fails and the the line blows free. It goes rearward from the pump to the hydroboost. The one marked is the pressure from hydroboost to steering box.
Old Feb 15, 2015 | 06:20 PM
F350-6's Avatar
F350-6
What Roland said. Pump to hydroboost is what you want to change since it's the one that always blows out the side of the reservoir.
Old Feb 18, 2015 | 07:52 PM
AllaboutMPG
On the list are:
Oil cooler seals(it leaked last cold spell so it's time)
injectors
HPOP hoses
Riff Raff Billet wheel
Riff Raff plenum inserts
UVCH's
Vlv cover Gaskets
Passngr side fuel line(mines not leaking but has a taped up wear spot)
Hydra w/TW tunes
Glow Plugs(OEM)
oil by pass filter set up (DIY similar to Springr pop and woodnthings)
Obviously I'll need pedestal and turbo o-rings, injector o-rings, extra coolant, Seals for fuel lines(not sure what size??). Already have 4 gal T6 and filter, ELC, What am I missing supply wise?
I re-torqued rocker hardware last time I was in and will obviously torque the injectors(engine hot) this time. What else do I need to look at?????
Thanks in advance for your help,
So I've added a couple of items to the list.
International Water pump w/filter
205 thermostat
My water pump came in today and and it has two pipe thread openings at the outlet. I will have to try a couple of different fittings at different angles once I get the old one off and can hold the new one in place to see what will work.
Since I will have the fan, water pump, turbo, valve covers, etc, etc off do you guys see anything I'm missing maintenance wise.
Fuel bowl and EBP were addressed not to long ago and fan belt is fairly new. Already ordered a new coolant temp sensor. Turbo has zero play so I'm not gonna risk screwin up a rebuild. I will do another boost leak detection when I get ready to tear into it and if plenums are leaking I will remove and reseal. I have the Ford grey RTV. Is that what is used on the plenums?
I know this is a lot of questions but I trust you guys to help[ me get it done right.
Paul
Old Mar 2, 2015 | 09:48 PM
AllaboutMPG
So I'm preping to throw some parts at my truck and would appreciate your input on things to do while I have it opened up and things to stockpile as I get ready. The idea is a little upgrade and a little preventative mtc.
I know I could get more power and better mileage with single shots but I just don't trust after market electronics. I want to be able to completely remove the chip and run off the PCM if need be so I'm staying with stock injectors. I don't need big power, want to join the 500K & beyond club like F350-6 just did, and want a little more omph when towing hence the Hydra. This is more about reliability.
On the list are:
injectors
HPOP hoses
UVCH's
Vlv cover Gaskets
Hydra w/TW tunes
Glow Plugs(OEM)
205 thermostat
Obviously I'll need pedestal and turbo o-rings, injector o-rings, extra coolant, Seals for fuel lines(not sure what size??). Already have 4 gal T6 and filter. What am I missing supply wise?
So day 1 is over and I made some decent progess. Did a boost leak check before I started just to make sure everything was tight. Only leaks were at the plenum boots. Glad I got the plenum inserts so I can tighten them better without worrying about crushing them.
Note to self--- do not raise pressure on boost leak checker unless your sure you have clamp tight. When that thing blows out it'll make you soil yourself. . Glad noone was standing in front of it
Pulled the degas bottle, radiator, fan and shroud to give me room to work. At 5'8" I can stand on the steering linkage and it's almost the perfect heigth and makes the reach to the turbo and valve covers a ton easier.
So far:
Injectors in and 1st torque
UVCH's
Glow plugs
UVC gaskets
Billet wheel in and turbo hooked back up(what a pain, glad the Bro-in-law stopped by to help)
passenger side fuel line replaced
New Hpop hoses in
Plenum inserts in
New water pump has the extra pulley boss ground down, viton o-ring installed in the cutoff valve, and a coat of paint on it.
Sorry no pics. I was working by myself for the most of it and with all the work time feels like it's flying by.
Tomorrow comes the water pump install, oil cooler rebuild, oil by-pass filter install, and the power steering pressure line R/R and flush. If I have time there's still the diff fluids and tranny flush. We'll see.
Thanks to everyone here who has taken time to share the many how to's, especially Nicmike for the water pump write up and SpringerPop / Woodnthings for the oil bypass DIY info.
eightball8
Dec 8, 2015 11:44 PM
beersy50
Aug 27, 2014 09:10 AM
mabc926
May 27, 2010 04:56 PM
drewdole
Jan 4, 2010 10:12 PM
chipper
Oct 20, 2006 02:03 PM
