Sponsored by: Auxito
Overdrive light blinking
Old Oct 27, 2003 | 03:32 PM
  #46
LxMan1's Avatar
LxMan1
Well, scanning if free at most parts houses so the paycheck thing isn't a viable option there, if you can't afford free, then you must reallly be poor!!
Jimmy
Old Oct 27, 2003 | 08:37 PM
  #47
Racerguy's Avatar
Racerguy
I think if it was mine I would have it gone through the whole way.
At least that way there isn't any doubt as to the condition of the other parts in the transmission and you hopefully wont have to do it a second time.
Old Oct 28, 2003 | 08:14 AM
  #48
Rhurt's Avatar
Rhurt
That is what I decide to do. Just wouldn't make sense (or cents) to skimp on it once someone is inside it.
Thanks for all your advice and assistance.
The only bright moment in yesterday was when I finally got to pick up my '56 chevy that now has a new interior and some great looking new Crager S/S Wheels.......
Old Oct 28, 2003 | 11:04 AM
  #49
LxMan1's Avatar
LxMan1
Did he say Chevy? tsk tsk.
I guess it's not so bad to have a classic one.
Does it have a 347 stroker 5.0 in it????
Jimmy
Old Oct 28, 2003 | 12:35 PM
  #50
Rhurt's Avatar
Rhurt
No sir! I'm not into all that. Originally when I drove it in high school and college it had a 235 straight 6, then in 1991 I had a rebuilt 283 put in it and that's as far and as fast as I care to go.
Old Oct 28, 2003 | 01:03 PM
  #51
LxMan1's Avatar
LxMan1
Sounds pretty nice. Been in the family awhile I guess.
Jimmy
Old Oct 28, 2003 | 01:11 PM
  #52
Rhurt's Avatar
Rhurt
Yep, My dad bought it in 67 for $200 from a farmer who was hauling hay in it......
Old Oct 28, 2003 | 01:15 PM
  #53
LxMan1's Avatar
LxMan1
Them there old cars has bome big ole trunks!!
I bet it took awhile to get all of the hay out of it.
Jimmy
Old Mar 23, 2004 | 02:18 PM
  #54
WAromando's Avatar
WAromando
Wow.... what an interesting trail...
I have a blinking over drive light. The initial thought was a transmission problem. I recently had a transmission kit replaced. With the cold weather (sub-32), my transmission was clunking, shifting rough.
I ran an Internet search and tranced it to a possible Vehicle Speed Sensor. I once had a vehicle over-heating, put some dollars into it to end up finding on my own that the fan connector was cracked. There could be moisture or damage to the connector.
Next, there came up a tie to the Vehicle Sensor and the ABS system. Now, something clicked. I know I need my brakes done.
Also, there is a connection between Direct and Indirect Tire Pressure Measuring and ABS Systems. My tire pressures have been off or low; and I had a flat tire last week.
Taking care of the little things, servicing my brakes - changing pads and rotors, cleaning the drums, checking and cleaning the ABS sensors, checking my tire pressure, having the tires balanced and replaced if necessary (two out of four are old), I can easily save expensive transmission service or replacement.
Also, having the transmission service or replaced might not even correct my problem. Even the Vehicle Speed Sensor was estimated at only around ~$42.
Great brain-storming by the collective thoughts of all.
WAromando
Freehold, NJ
Old Mar 23, 2004 | 06:24 PM
  #55
Racerguy's Avatar
Racerguy
Welcome aboard WAromando
BriR
18
Apr 16, 2021 09:08 PM
Ollison
1997 - 2003 F150
Jun 19, 2013 12:05 PM
balingwire
Jan 1, 2011 04:53 PM
jonnyboy78023
18
Mar 24, 2008 11:00 PM
nothingbutford
Feb 7, 2002 08:02 AM
