What shocks do you use and why
Old Feb 12, 2015 | 06:31 PM
sscarboro's Avatar
sscarboro
About time for me to put shocks on my 2WD F250 and I'm interested in hearing what the members here use and why. I have ride right air bags and tow an 11,900 lb fifth wheel occasionally.
Thanks in advance
Steve
Old Feb 12, 2015 | 11:53 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I was a diehard Monroe guy until I got these Rancho 9000XL shocks.
Adjustable and difference is night n day.
Josh
Old Feb 13, 2015 | 12:13 AM
jswartz84's Avatar
jswartz84
Rancho 9000's are my choice.
Why? Ride comfort and durability.
Old Feb 13, 2015 | 01:03 AM
tacticalmedic469's Avatar
tacticalmedic469
Rancho 9000's.
Old Feb 13, 2015 | 01:21 AM
Bently_Coop's Avatar
Bently_Coop
I have Bilstien 5100's on the front of mine and Pro Comp ES9000's on the rear. Was a cost thing at the time for the rears. It seems the Rancho 7000's, 9000's and Bilstein 5100's are the way to go for towing and such, especially all over FTE. Rancho is a sponsor as well so you may be able to locate a discount or see which you need specifically through them.
Old Feb 13, 2015 | 02:45 AM
KDAVID1's Avatar
KDAVID1
Josh
Same here then after seeing all the stuff on here about the Rancho 9000xl I decided to give them a try when I did the shocks on a buddies Explorer. He said they were awesome. Those will be what I use when I need to change
2006 F350 4X4
Old Feb 13, 2015 | 05:57 AM
jsm180's Avatar
jsm180
Bilstein 5100's front and rear, no complaints empty or pulling the 5th wheel. In all my years driving I have never felt the need to adjust my shocks and it's just another failure point.
Old Feb 13, 2015 | 11:24 AM
diesel_dan's Avatar
diesel_dan
Another Rancho 9000 fan here. Couple of reasons: Top of the list is like you, we go from fully loaded to empty and everything in between. So fully loaded I run max dampening and it makes a huge difference (we also run bags).
Second one I don't see talked about much is if you start playing with different tire sizes like we initially did (bigger), as I could control the jounce on settings of 3-4, particularly up front. I'm now down to just sightly wider BFGs and don't really care for them, so I'll be going back to stock size next change.
So it's all about being able to tune them as your load/other conditions change...
Oh yeah: you can buy a remote kit for the 9000s so you can dial in your dampening from the cab
Old Feb 13, 2015 | 11:40 AM
Forddiesel06's Avatar
Forddiesel06
I to have been studying on what to replace my worn out shocks, and I am going with Rancho 9000's.
Old Feb 13, 2015 | 11:57 AM
jbird905's Avatar
jbird905
9000XL here too. One day I wanted to test them and dialed them down to see if it would feel "floaty" like a GM (truck was empty). After 20ish miles on hwy, I swore it felt like I was bouncing alot (stiff, not floaty). Stopped and checked, realized I turned dial wrong way, lol. So there really was a difference.
BTW, I did lube the dials with grease to help protect them (Colorado) and they still turn easy.
Old Feb 13, 2015 | 01:26 PM
Rancho Suspension's Avatar
Rancho Suspension
Former Vendor
9000's, since I tow occasionally.
dremtofford
Apr 24, 2019 01:22 PM
Gordon-0
Feb 27, 2012 03:57 PM
rambaseball45
1997 - 2003 F150
Mar 24, 2009 12:53 AM
eigood56
Mar 24, 2008 06:33 AM
wendell borror
Offroad & 4x4
Apr 7, 2006 09:48 AM
