Antifreeze
Old Feb 12, 2015 | 03:23 PM
vtown00's Avatar
vtown00
Antifreeze
Since I'm flushing my system from the oil/antifreeze mix I have going on now, is there a product preference between this Peak Fleet or I see two Rotella ELC and Rotella Ultra ELC for my 2001
Peak Fleet PEAK COMMERCIAL & INDUSTRIAL | FLEET CHARGE | HEAVY DUTY COOLANT/ANTIFREEZE | FAQS
Shell Rotella http://s07.static-shell.com/content/...s-brochure.pdf
Anybody use the Ford additive? http://www.fordparts.com/Products/Ch...-Coolants.aspx
Old Feb 12, 2015 | 04:59 PM
Pikachu's Avatar
Pikachu
The Peak fleet charge is a regular ethylene glycol coolant, but it is pre- charged with SCA additive. It requires checking and adjusting the SCA level periodically. Peak also makes an ELC that is more comparable to the Rotella ELC, Final Charge.
Old Feb 12, 2015 | 10:53 PM
Poolguy601's Avatar
Poolguy601
This is what we use in our fleet. Its available at our local auto supply stores.
http://yanmarhelp.com/images/texacoNitritefree.pdf
Old Feb 15, 2015 | 02:57 PM
vtown00's Avatar
vtown00
Hey last question on this, the truck is already 15 years old, but if I go to the Rotella ELC is there much of a benefit to adding the coolant filter, it has the best benefit with the green coolants right?
Old Feb 17, 2015 | 03:04 AM
Stewart_H's Avatar
Stewart_H
There's a huge difference between those two coolants. Huge.
Do your homework and know the difference and what you want to run. Check out the thread I have posted in this forum regarding coolant information. Just use the search term "Gooch" and you'll find it.
Adding a coolant filter is always a good idea.
Stewart
Old Feb 17, 2015 | 09:35 AM
vtown00's Avatar
vtown00
Thanks Stewart, the main thing with any ELC seemed to be availability, but I was able to finally find some on the shelf at a local store. Now if I could just figure out the easiest way to get the rear drain plugs out, I don't think they've ever been touched I've been soaking them in Blaster for days, and with my larger starter I'm thinking I need to take it off to get pass side. ��
Old Feb 17, 2015 | 09:56 AM
AllaboutMPG's Avatar
AllaboutMPG
vtown00,
Glad you found some. For those that may be looking in the future big rig repair shops often have over the counter sales. I get Rotella concentrate at about $13 a gallon. Look for these truck centers or something like them
Kenworth, Hino, Ford, Volvo, Isuzu ? MHC
Old Feb 17, 2015 | 01:42 PM
Stewart_H's Avatar
Stewart_H
I just bought a case from Amazon 3 days ago.
Amazon.com: Delo (227808497-6PK) Extended Life Antifreeze/Coolant - 1 Gallon, (Pack of 6): Automotive Amazon.com: Delo (227808497-6PK) Extended Life Antifreeze/Coolant - 1 Gallon, (Pack of 6): Automotive
Now that I'm not mobil, here's the link I was referring to in my previous post: Gooch's Coolant Flush Procedure and In-Depth Coolant Information
Check it out and you'll find instructions for how to access the drain plugs without removing the starter.
Stewart
Old Feb 17, 2015 | 07:52 PM
vtown00's Avatar
vtown00
ok I see it states put a 1/4" ratchet head there, but in no way will that give me enough torque to loosen this rusted plug on either side of the truck, maybe if I didn't live in salt belt Ohio. I feel like if I push any more I'm going to round the plug out, I sprayed blaster yet again an will try later.
If I'm not able to get them off am I better off keeping green coolant in it?
Old Feb 17, 2015 | 10:58 PM
bakerbuilttracks's Avatar
bakerbuilttracks
Lots of soaking and take a small butane torch and heat the block AROUND the plug. This will expand the metal around the plug loosing it. Thats just how i get stubborn bolts out. Worst case giver all u got ! If it strips out weld a piece of flat bar or round stock to the plug and that should get it out. Ive sone that a few times.
And Stewart correct me if I'm wrong and i hope I'm not just for my wallets sake and a waste of my time but i was going to suggest to the OP and anyone else if you can't find coolant you can always stop by your local CAT Dealer and pick up CAT-ELC EC1 which is what I'm running ! (do i get a gold star for that or a red star ) ?
Old Feb 17, 2015 | 11:10 PM
hydro man 17's Avatar
hydro man 17
If you can't get the plugs out you can just re-flush with distilled water 3-4 times ( running to operating temp ) and should be good. A bit of a pain and costs a little bit but it will get the job done. Now if I had just paid attention and used the correct CAT ELC EC-1 coolant instead of the conventional ELC I would not need to do it again.
Old Feb 18, 2015 | 07:16 PM
GEugeneS's Avatar
GEugeneS
I used Gooch's procedure a couple of years ago and it worked perfectly. Didn't have the guts to experiment with different brands of antifreeze because of the cavitation issues so I used Ford Gold concentrate. As I remember, it was rather expensive. Didn't have problems with the plugs either.
Old Feb 19, 2015 | 08:32 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Tractor Supply sells Rotella ELC concentrate for $15.
grantorino
Mar 31, 2007 08:04 PM
blrman1962
Mar 1, 2007 07:53 AM
ordy1
Dec 22, 2006 08:38 PM
Rockies
Nov 18, 2003 10:38 AM
E350turbo
Nov 2, 2003 05:16 PM
