Cam sensor?
Old Feb 12, 2015 | 10:50 AM
nmlewis's Avatar
nmlewis
Cam sensor?
So I had my mechanic friend come by and hook up his computer.
It turns out that when my #3 injector died the computer was compensating for it.
So fuel pressure is good, but the computer was still compensating like #3 was out still.
#3 injector was out of sync with the rest of the injectors.
So he synced it and reset the cam sensor. It cleaned right up and ran great.
Now that I have started it a few times it feels like it is rough again.
Could my cam sensor be going bad? it didn't throw a code yet.
My crank sensor has a leak could it be going bad to cause this too?
Old Feb 12, 2015 | 07:26 PM
dannyboy950's Avatar
dannyboy950
Sorry somebody is blowing smoke or is unfamiliar with the 6.0.
You can't sync a single injector or reset the cam sensor.
He probably meant cleared the codes. It would run good until it ran long enough to reset the hard codes. Maybe he was hopeing it was just a glitch and would stay cleared and work. Unless it is leaking thru the crank sensor it is probably just the o-ring on the sensor.
Ranger Bob
Oct 27, 2017 06:29 AM
cmiller1229
Apr 14, 2010 01:19 PM
semperfipsd
Aug 24, 2004 08:18 PM
96ford4x4turbodiesel
19
Jun 20, 2004 01:15 PM
