another cam sensor ?
Old Aug 23, 2004 | 02:29 PM
semperfipsd's Avatar
semperfipsd
After studing this forum intently I decided it would be wise of me to have an extra sensor on hand. However, when I went to buy one I was informed that not only do you have replace you cam sensor if it goes bad but you have to also reset you computer codes. Is this correct? I was lead to believe by this part guy that just having a good cam sensor would not get my PSD going again. The error code would have to be cleared prior to my PSD starting agian. But I havn't seen this being discussed when replacing a cam sensor.
Old Aug 23, 2004 | 02:32 PM
gotdiesel's Avatar
gotdiesel
most of the time a bad sensor will not set off a code. when mine went bad my truck would die occasionally for a couple of months before i replaced it and it never threw a code. if it goes bad and you have one and a wrench to replace it you should be fine.
Old Aug 23, 2004 | 03:44 PM
wlihntr's Avatar
wlihntr
i have never heard of the code thing either, but if it were to be a problem just turn on your headlights and disconnect both batteries for 15-20 mins and that should reset the PCM then you should be set to go.
Old Aug 23, 2004 | 03:45 PM
99PSDCREW's Avatar
99PSDCREW
Semper Fi,
I replaced mine also when the truck died occasionally. No codes, and no problems since replacement.
btw, where are u stationed? 29 4 me.
99PSDCREW
Old Aug 23, 2004 | 03:54 PM
semperfipsd
Thanks for all the responses. I thought I was getting bad info from the parts guy. I trust you guys before some parts/counter boy! 99psdcrew, I was station on the east coast '89-'96 (Quantico, Camp Lejuene, & the armpit MCLB Albany, Ga) would love to see pic of your 99PSD sounds on your profile.
Old Aug 23, 2004 | 11:57 PM
96ford4x4turbodiesel's Avatar
a couple of months ago my truck would start spuddering and wanting to die and i got a code, p0344 if im correct i think that means camshaft posision senor malfunction or something like that, well anyways i went with my gut feeling and bought a cps and put it in my truck and havent had anymore trouble with it
Old Aug 24, 2004 | 12:30 AM
johnsdiesel's Avatar
johnsdiesel
When mine went it did not throw a code either.
Old Aug 24, 2004 | 06:20 AM
rockyrider's Avatar
rockyrider
Mine did throw a code, I used my Superchips Programmer to reset it a couple of times before finally replacing CPS. It was an intermitent code, forgot exactly what it was.
Old Aug 24, 2004 | 08:49 AM
Craze's Avatar
Craze
Advice
semperfi;
After working in solid-state electronics for over 30 years I have one premium bit of advice for everyone: "Do not work on electronics hot."
I know 12 volts won’t hurt you but think about your truck. Before removing (actually replacing is more important) the CPS disconnect both batteries. This should make resetting the computer codes a mute point.
Old Aug 24, 2004 | 02:19 PM
99PSDCREW's Avatar
99PSDCREW
Still need to buy a digi camera, should be in Sept. Yes, she does look (red)and sound good!!
Old Aug 24, 2004 | 08:18 PM
overtime_ranchero's Avatar
overtime_ranchero
the OBD systems reset the codes on their own after a set number of cycles without the problem. Explains why SES lights come and go.
