Transmission temp too cool?
Old Feb 14, 2015 | 11:39 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by F357
So if they bothered to put a 165 degree thermostat in it, somebody, somewhere must have decided it runs better at that temperature or higher, is that right?
Wouldn't we then benefit from a transmission HEATER in the coolant line?
Is there any particular reason this transmission runs cooler than almost any other automatic?
We debated adding a heater for the trans. In the end the VERY small benefits couldn't be justified to the added cost. The only benefit we could prove was a tiny fuel economy improvement.
Originally Posted by diesel_dan
I guess I'd assume the opposite: They didn't feel the fluid needed to be cooled until it got to that 165-170 range...
Perhaps that is why they went to a full filtration filter? These trans do run nice and cool, that is for sure.
Maybe Mark knows why they went to the full filtration versus the bypass?
Because the solenoids are very sensitive to dirt. The full flow filter removes much more than the bypass can.
Old Feb 14, 2015 | 05:23 PM
F357's Avatar
F357
Originally Posted by mhoefer
There is no need to protect from colder temperatures or warm the transmission fluid.
There is no need to heat the transmission. I have run my truck in -45 C weather for a day and the tranny temps never made it over 100 f. Doesn't hurt a thing, the tranny works fine.
I know I don't NEED to do anything. I'm talking about making it better. It's pretty obvious that the Ford engineers either failed miserably or cheaped out entirely when designing quite a bit of my vehicle. Obviously my transmission needed improvement or they never would have added the in pan filter. Something was wrong at the factory.
There is a need to heat the fluid in an automatic trans. They shift better warm. They get better fuel mileage. And they burn off any moisture better. It's like switching to 10w30 in your engine, lots of people do this for fuel mileage. Hotter fluid = lower viscosity = better shifting = better MPG. Aftermarket transmission coolers often come with thermostats to prevent over cooling. My trans definitely shifts better at 140 then at 60.
It would also allow my filter to work better. Right now it never filters more than 10% of 10%. I bet I never have to change the filter! Warmer temperatures should also allow the very expensive synthetic ATF to last longer by burning off moisture.
Old Feb 14, 2015 | 06:11 PM
mhoefer's Avatar
mhoefer
If you are using the truck for its intended purpose, hauling a load, towing heavier, it will be filtering fine. I get what you are saying but it is overkill in my opinion, because the SP and LV fluid performs well at a wider temperature range. You could look into a tranny pan heater to go with an engine pan heater, which I agree should be on there and they should be using a circulating water heater rather than a single block element. But, for what it will get you, in the long run, Mark K has explained, there is only a small marginal improvement in fuel mileage at best. There are. Many things you can do to improve overall winter cold weather performance, a winter front, battery maintenance, circulating coolant heater instead of block heater or both, coolant filter, modified 2008 pan, increased capacity pan, you could in theory even tap the pan for submersible oil pan heater for the tranny. I just don't think it's going to be worth the effort. Just my opinion, it's your Truck. You are getting the information from Mark and he is spot on, knows a lot. What you do with that is up to you.
Old Feb 14, 2015 | 07:37 PM
69cj's Avatar
69cj
They did improve on it but there's nothing wrong with your tranny set up. All things evolve. The 6.0 torque shift is one of the best trannys on the market. If your that disenfranchised with it I'd get something else.
Old Feb 14, 2015 | 07:46 PM
F357's Avatar
F357
LOL. The intended use is to use it however the end user sees fit. I'll bet more people use their 6.0 to get groceries than they do to tow heavy loads. I do not heavily load my truck regularly, and there is nothing wrong with that. I do plan on adding a transmission pan heater, but only a small one. I always use my block heater, even when it's warm out. I suspect the trans cooler works so good on this truck that it might cool itself back down as soon as I start driving. I will be installing the 200* thermostat as well.
Why not use a free heat source from the engine? It wouldn't be hard to plumb a heat exchanger into a coolant/ATF line, very simple plumbing. Not sure what heat exchanger would be best.
I never said there was anything wrong. Again, I was talking about making it better. Look at the 200* thermostat thread. Did everybody say "there's nothing wrong with the Ford stat don't bother"? The Ford thermostat is of a bad design and the aftermarket one improves fuel mileage. It "works" just fine from Ford, it doesn't have to be broken to make it better. It stands to reason the trans can be made better than what Ford sold also.
Old Feb 14, 2015 | 08:12 PM
KDAVID1's Avatar
KDAVID1
I don't think the tranny is like the motor whereas more heat makes it better. As far as I'm concerned what ever Mark K says about these transmissions is the final word. He helped engineer them for crying out loud
2006 F350 4X4
Old Feb 15, 2015 | 06:18 PM
mhoefer's Avatar
mhoefer
Fair enough, you do what you want. Mine doesn't get worked hard in the winter either. Just not worth it to have two vehicles for me.
glockholiday
Nov 30, 2014 07:20 PM
craziejoker
Dec 29, 2012 05:08 PM
VHOLT
Modular V10 (6.8l)
16
Oct 29, 2010 05:03 PM
Texascadillac42
Dec 21, 2008 07:23 PM
learmoia
Dec 29, 2006 10:16 PM
