That's a fumoto on one end correct Mark? Did you make that up or find it somewhere? Hope the angle points in the right direction when you tighten 'er up
LOL - I have 180 degrees available for it to be OK!!!
It's an EZ drain valve. Similar to Fumoto. Some say a little better.
I measured the space and the adapter and valve will fit (measure twice / cut once lol). That is what was a challenge in the project - fabbing it to fit. I ordered the 90 on the end as a "hope and a prayer". It just screws off, so it is no big deal if it does not fit (and Scott - it makes the final orientation a moot point as well - lol). If I take the 90 off, the stream may hit the drive shaft and splatter, but I will just have to try it out and see.
It would definitely be good for a 2WD!
I may have to take off the manifold cover to fit it all in, but will let ya'll know on that when I do it.
Too late coming home from work to get it done. Will do it tomorrow.
here are the installed pics. I did indeed have to remove the HFCM manifold, but left the hoses attached - I only needed a little bit of extra room to get it installed.
Not unexpectedly, the 90 degree elbow did not fit.
