Aftermarket Motor Mounts
I bought a set of Trans Dapt 302 motor mounts and a C4 trans cross member for my 64. I'm looking for help determining the correct location to install the mounts and cross
member on the frame.
If anyone has used these and could provide some measurements on where they installed them, please let me know
The trick is to try and set the engine and transmission so you don't have to shorten or lengthen the driveshaft.
Work from where the tailshaft meets the drive shaft and go foreword. If you are lucky, the engine will not hit the firewall or the radiator.
Its one less thing to do if you can make the existing driveshaft work.
Also make sure your tranny linkage will work before you commit to placement.
Big_Texxan
21
06-08-2016 06:50 PM
