head gasket problems!!!!
Old Feb 10, 2015 | 08:48 AM
patino1's Avatar
patino1
I have head gaskets blown engine is 03 or 04 bought the truck was supposedly an 07 got screwed but it was running good so I don't really know the actual mileage on the engine it's it worth it bulletproofing this engine or replace it? thanks
Old Feb 10, 2015 | 10:00 AM
Asheville Engine's Avatar
Asheville Engine
Former Vendor
Check out our prices, compare them with what you would need to spend on parts and weigh your options. AshevilleEngine.com
Old Feb 10, 2015 | 03:15 PM
RideDiesel88's Avatar
RideDiesel88
I don't see why replacing the engine would even be an option. How do you know the head gaskets are blown???
Old Feb 10, 2015 | 03:45 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Leaking headgaskets are a common problem on these trucks and because of that they are also a common misdiagnosis. If you left out the details of troubleshooting for the sake of a short post, drop back in with some more info. It's hard for anyone to help much online without details. If you or a friend are mechanically inclined, and you're confident of the head gasket diagnosis, it would be a no-brainier to pull the heads and see what's up. If there's lots of wear in the bores any damage to Pistons, cracked heads etc. That could help decide which way to go.
If your suspicious of the head gasket diagnosis, post up what's been done so far and we'll try to help .
Old Feb 10, 2015 | 06:27 PM
Per4mance's Avatar
Per4mance
Now that's a great answer!
Old Feb 10, 2015 | 06:39 PM
CPB1's Avatar
CPB1
Agreed, Rusty does it again. Great post
Old Feb 10, 2015 | 07:07 PM
11jjonn's Avatar
11jjonn
Hello .....
Where'd the OP go ??
Someone needs to put out a BOLO -
(or was that just another Duramax poster ??)
Old Feb 10, 2015 | 07:09 PM
Rusty Axlerod
Thanx guys, just tryin to help . The 6.0 is such a cool, interesting engine. Just hate to see folks getting started with big problems right off the bat.
Old Feb 11, 2015 | 07:51 AM
Asheville Engine
Former Vendor
I only brought up the possibility of engine replacement in case he has his heads checked and finds out that they are both cracked, which happens. If he needs heads, gaskets, ARPs and he has a high mileage truck, it's sometimes more cost effetive in the long run to spend $4,895. on a long block
Old Feb 11, 2015 | 08:34 AM
Rusty Axlerod
10-4 Asheville, engines are what you folks do. Thanks for being one of the companies who make this site possible!
gccch
Jun 8, 2013 03:57 PM
rlay302
Dec 9, 2012 01:32 PM
Narwhal
15
Feb 18, 2006 04:25 PM
patriottow
Jun 6, 2005 10:00 PM
