Head gasket issue
Old Dec 8, 2012 | 03:07 PM
rlay302's Avatar
rlay302
Head gasket issue
It appears that I have a small head gasket issue? Did compression check on my engine today and noticed anti-freeze blowing out of the number two cyclinder when the engine was cold. Now when I did it again with the engine at operating temp there was nothing coming out.
How hard is it to change the head gasket?
Old Dec 8, 2012 | 03:58 PM
HIO Silver's Avatar
HIO Silver
Depends. How wrench-worthy are you? i.e., what is your skill level and do you have the time and tools?
Old Dec 8, 2012 | 04:38 PM
turbohunter's Avatar
turbohunter
If you are asking the question you might want to get a little help from a knowledgable buddy. It's worth doing yourself but have someone with you that knows whats going on.
Old Dec 8, 2012 | 05:13 PM
nine inch rear's Avatar
nine inch rear
If your going through the trouble of replacing the gasket, get the heads checked out for any cracks. Also, get the correct size tap and clean up the threads of the head bolts.
Old Dec 9, 2012 | 12:34 PM
rlay302's Avatar
rlay302
Thanks for the replies,
Yes I have the tools and actually rebuild this engine about ten years ago. I test all the cylinders for pressure and the bottom end appears to be good. And yes I will have both the heads checked for cracks but, I don't want to have them reworked because it may cause issues with the bottom end.
I was really wondering if, there's anything out there that may seal the small leaking crack instaed of having to tear the whole top end apart?
Old Dec 9, 2012 | 01:16 PM
rlay302's Avatar
rlay302
Old Dec 9, 2012 | 01:32 PM
nine inch rear
Honestly, Ive tried that stuff a few times as a patch. Some techs say it works, but for me it didnt. If you do use it, theres several steps that have to be done for it to work. Its all listed on the bottle. In other words, you dont add to coolant and drive off.
One thing that comes to mind if you pull the heads. There are a couple of alignment collars that seat in the block. These help the head gasket stay in place and align the head as you lay it back on the block. Sometimes these collars pull out of the block and stay with the head. Get some pliers and pull them back out, and tap them back into the block. Match up your head gaskets for left and right, and that the gasket has proper steam holes as your old one.
dairydude
Mar 13, 2019 09:46 AM
Chevyboy_0
15
Apr 26, 2008 05:30 PM
nmarlowe
Sep 1, 2004 07:25 PM
niteowl
Apr 21, 2004 01:56 AM
