Headlight problems
Old Mar 27, 2009 | 08:48 PM
Vinford's Avatar
Vinford
Headlight problems
1996 F-250 XLT 460 automatic 2wdr.
Low beam and day time running lights wont work.
Only hi beam works.
Indicator on dash also not working.
Where to start?
I checked the bulbs themselves and they seem OK.
Old Mar 27, 2009 | 09:14 PM
truckrider814's Avatar
truckrider814
Might want to check the headlight switch and the fuse's sometimes the switch will short out. when mine did the marker lights came on on the first setting but when i turned on the headlights they went out. after i changed the headlight switch and a couple blown fuses works good as new.
Hope this helps
Kyle
Old Mar 27, 2009 | 09:28 PM
Vinford's Avatar
Vinford
Fues under the dash or under the hood?
Old Mar 27, 2009 | 09:43 PM
Old93junk's Avatar
Old93junk
Since its a Canadian truck it could be the DRL module giving you the problem, was kicked around here a couple a weeks ago on the forum.
Old Mar 27, 2009 | 11:06 PM
Vinford's Avatar
Vinford
In this part of the forum?
Old Mar 27, 2009 | 11:08 PM
Old93junk's Avatar
Old93junk
Yep. about 2 wks back, short search should turn it up.
