Another Rating Plate Request
Old Feb 9, 2015 | 06:20 PM
AlsRyd66's Avatar
AlsRyd66
Hello all. My first post, although a member since Nov 2013 when I got a 1966 F100 Stepside, Short Bed, 352/3 spd. I read this forum quite a bit, but, usually search for help on issues I have. Unfortunately, the rating plate is gone and the former owner never found it. I plan on getting a replacement from Marti Auto Works. Here is what I have so far:
Warranty Number: F10 YK 805691
W.B.: 115
Color: L (Holly Green/Dark Green)
Model: F100
Body: ???? I'm confused with the numbers/codes. It has the black vinyl bench seat, standard cab and stepside.
Trans: C
Axle: ?????? Rear End tag has 1st line: WDM-M
2nd line: 3 50 6AA 301
Max CVW lbs: 5,000
Cert. Net HP: 208
RPM: 4400
DSO: Have no clue on this.
Any corrections or info on the question marks would be appreciated. I'll post pic's as soon as I can figure out how as it states I can't post attachments????. Currently the truck is down to the frame in pieces. Thanks to all in advance
Old Feb 10, 2015 | 02:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by AlsRyd66
My first post, although a member since Nov 2013 when I got a 1966 F100 Flareside Short Bed, 352/3 spd. I read this forum quite a bit, but, usually search for help on issues I have. Unfortunately, the Warranty Plate is gone and the former owner never found it. I plan on getting a replacement from Marti Auto Works.
Warranty Number: F10YK805691
Warranty Plate: WB: 115 / COLOR: L / MODEL: F100 / BODY: 381 / TRANS: C / AXLE: 08 / MAX GVW LBS: 5000 / CERT NET HP: 172 / RPM (net): 4000 / DSO: 41
Rear End tag has 1st line: WDM-M = See 08 AXLE code.
Ford = Flareside, a Stepside is a Chevrolet.
F10 = F100 2WD
Y = 352 2V
K = Kansas City MO Assembly Plant.
805691 = 1966, assembled January 1966.
115" Wheelbase.
L = Holly Green.
F100 = F100 2WD, 5,000 lbs. GVWR
BODY 381: 3 = Medium Green Crush Vinyl & Medium Green Wicker Pattern Vinyl / 81 = 81A Standard Cab.
C = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
08 = Ford 9" Rear Axle / 3.50-1 / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 (net) RPM
DSO code: 41 = Chicago IL Ford District Sales Office, where the original selling dealer ordered the truck from.
Air Cleaner decal: 208 (gross) HP .. The gross RPM is 4400.
I doubt the black seat cover is original. Painted Holly Green, the Standard Cab BODY code would be: 381
Trucks sold new in IL would have a DSO code of: 41
1966/69 Warranty Plate is the same, but Marti only has codes for 1967/79. So, you'll have to furnish the above Warranty Plate info.
Old Feb 10, 2015 | 08:26 PM
AlsRyd66's Avatar
AlsRyd66
Thanks for the info, corrections and response. From the past readings, I knew I would get the right answers. Sent to Marti today for the new tag.
Hope these 2 pic's show up.
Purchased Nov 2013
As of 2 weeks ago
Cab was a rust bucket and other major issues so down to the frame it went.
HAMS64
Aug 15, 2019 12:12 PM
trossol
Jun 27, 2015 02:39 PM
IntrstlarOvrdrve
Dec 11, 2014 05:12 PM
cowmankev
Oct 6, 2013 07:47 AM
Gembone
Mar 4, 2013 11:53 AM
